show distinct bars of stacked bar chart
Neelam
Post by Neelam » Wed Apr 07, 2010 5:14 am
Hi i have a stacked bar chart and there are 11 bars with different colors stacked on each other. The problem is that there is no border between the bar sections, so its not easy to see distinguish the different bars as the colors to be used are not very distinct. i tried to put black border between them by-
Private Sub SetBarColor(ByVal aBar As Steema.TeeChart.Styles.Bar, ByVal aColor As Color)
aBar.Color = aColor
aBar.Pen.Color = Color.black
but this does not give me black border line between 2 bars. I have uploaded attachment called screenshotBarcolor.doc for your reference.
Neelam
Re: show distinct bars of stacked bar chart
Post by Neelam » Wed Apr 07, 2010 5:30 am
Also i d using transparent color of Pen for all bars-
aBar.Color = aColor
aBar.Pen.Color = Color.Transparent
but strangely it gives Pink line between the bars where bars have fill color of blue,light blue and Bue color between bars where bars have pink,orange kind of shades.Why is that? i am uploading another attchment called screenshotPencolorTransparent.doc for this one.
Post by Sandra » Wed Apr 07, 2010 11:38 am
Hello shikha,
I couldn't reproduce it with last version 4 of TeeChart .Net and next code. Please, check if next code works as you want in your application.
Private Sub InitializeChart()
        tChart1.Dock = DockStyle.Fill
        tChart1.Aspect.View3D = false
        Dim i As Integer
        For i=0 To 10
            New Steema.TeeChart.Styles.Bar(tChart1.Chart)
            tChart1(i).FillSampleValues
            tChart1(i).Marks.Visible = false
            CType(tChart1(i),Steema.TeeChart.Styles.Bar).Pen.Color = Color.Black
        Next i
        CType(tChart1(0),Steema.TeeChart.Styles.Bar).MultiBar = Steema.TeeChart.Styles.MultiBars.Stacked
aBar.Color = aColor
I'm not sure which is your problem with previous code. Please, you could explain exactly what is your problem with Color.Transparent?
Pen colours are automatically shaded (either darker or lighter) for aesthetic purposes. Please, see TeeChart .Net Demo concretely All Features\Welcome !\Chart styles\Standard\Bar
Neelam
Post by Neelam » Wed Apr 07, 2010 12:34 pm
thanks, i figured out that my problem is due to fact that i am having some bars with value 0 , so they are showing up with a thin line in a chart giving a false impression that its due to pen.color or border of neigbour bar. So please let me know how can i remove the bars with 0 values from stacked bar, please guide with piece of code. many thanks.
Neelam
Post by Neelam » Wed Apr 07, 2010 1:09 pm
Also i tried doing this i.e not to add the series if the value=0-
If Math.Round(dr("Series3"), 2) <> 0 Then
arBarSeries(IIABarSeries.DP).Add(dr("series3"))
End If
It solves this issue but gives another issue that in data table tool(Steema.TeeChart.Tools.DataTableTool associated with this chart) it does not display 0 , it shows blank!
Neelam
Post by Neelam » Wed Apr 07, 2010 1:29 pm
is there any way that the bars with 0 values are added to the data table( taht is they show 0 there) , but are not shown in the chart( currently they show up as a very thin line)
Post by Sandra » Fri Apr 09, 2010 10:17 am
Hello shikha,
I could reproduce your problem, and I consider as a bug report with number [TF02014788]. We will try to fix it for next versions of TeeChart.Net.
AIS
Post by AIS » Fri Apr 09, 2010 11:15 am
for 0 values you can use the "SetNull" method. I use it to avoid 0 value artefacts like you told.
Neelam
Post by Neelam » Fri Apr 09, 2010 1:23 pm
But then it would show blank/null in data table tool as well and so the purpose wont be solved. Or i misunderstood anything?
AIS
Post by AIS » Fri Apr 09, 2010 2:55 pm
I don`t know how the datatable tool visualize the case if you first add a 0 value and then call SetNull for this point. Anyway, the bar is not shown as a small line :)
Neelam
Post by Neelam » Fri Apr 09, 2010 4:38 pm
Thanks.. can you give me some example code( use of set null for this ) , it will really help..
AIS
Post by AIS » Mon Apr 12, 2010 5:25 am
for example like this:
CustomBar cb = new CustomBar(tChart1.Chart);
cb.Add(0, 1);
cb.Add(1, 2);
cb.Add(2, 0);
cb.Add(3, 4);
cb.SetNull(2);
Post by Yeray » Mon Apr 12, 2010 8:09 am
Hi shikha,
I think that there are two different problems here.
1. Stacked Bars with values = 0 are drawn as thick lines (TF02014788).
2. DataTableTool shows a blank space where it is a null point. I've added to the wish list the possibility to choose between showing or not the null points in the tool (TF02014789).
Neelam
Post by Neelam » Thu Apr 15, 2010 5:46 am
ok,thanks.
