Issue with placing the annotation
Posted: Wed Dec 21, 2011 12:18 pm
by 13051032
I have to place an annotation onrap the gh display based on some information from a text file. The text file defines the x-axis location (in my case time of sample with milli-secod precision) and the value of the annotation.
My problem is that no matter what the x-value is, the annotation is appearing on the center of the chart.
I am uploading a sample project to show this issue. There is a file called sample.txt in the debug folder that defines the x-axis location for the annotation as the second field. If you change the second field from 1 to 100, the annotation location continues to be on the center of the chart. How can i place the annotation correctly based on the x-axis value coming from the txt file.
I am using TChart v 3.5's latest version.
Thanks and best regards,
Re: Issue with placing the annotation
Posted: Thu Dec 22, 2011 10:09 am
by 10050769
Hello asupriya,
Using last version 3 of TeeChartFor .Net and your code I have get next image:
Can you tell us, if in previous image appears your problem?
