Xamarin.iOS Unified and TeeChart
TimeTell
Post by TimeTell » Tue Jan 13, 2015 10:49 am
I'm currently having issues with using TeeChart in a Xamarin.iOS Unified API project.
I have added the TeeChart.iOS.Unified.dll (version 2014.12.5) as a reference to my project.
However when I try to build it it comes up with the following warning:
Warning MT3005: The dependency 'TeeChart.iOS, Version=4.14.12.5, Culture=neutral, PublicKeyToken=null' of the assembly 'TimeTellApp, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' was not found. Please review the project's references. (MT3005)
And whenever I try to access a TeeChart class at runtime it gives the following exception:
The assembly 'TeeChart.iOS, Version=4.14.12.5, Culture=neutral, PublicKeyToken=null' of the assembly 'TimeTellApp, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' was not found.
I tried adding the TeeChart.iOS.dll (since TeeChart.iOS seems to be what is missing) in addition to the TeeChart.iOS.Unified.dll but doing this gives the following build error:
Cannot reference "monotouch.dll" and "Xamarin.iOS.dll" in the same project.
What could be the cause of this issue?
Re: Xamarin.iOS Unified and TeeChart
Post by Pep » Wed Jan 14, 2015 1:00 am
I've been able to reproduce the problem by using the Unified version downloaded from our web site at the customers download page.
I've also fixed and a new update for that version will be posted asap. In meantime, I've just sent an email directly to you in oder to allow you to check this fixed version.
