Marks Overlapping
XamarinProgrammer
Marks Overlapping
Post by XamarinProgrammer » Thu Sep 08, 2016 8:25 am
Hi Guys,
I have a chart with 3 bar groups:
My problem is that the marks on top of the bars are overlapping. Making some of them unreadable.
I have tried applying this solution:
http://www.teechart.net/support/viewtopic.php?t=5160
Similarly I created my own method to reposition the marks which I triggered AfterDraw:
(Not optimised, simple implementation just to serve its purpose)
private void repositionMarks ()
			Rectangle zero = new Rectangle();
			for (int k = 0; k < bar1.Marks.Positions.Count
			      && k < bar2.Marks.Positions.Count
			      && k < bar3.Marks.Positions.Count; k++)
				SeriesMarks.Position pos1 = bar1.Marks.Positions[k];
				SeriesMarks.Position pos2 = bar2.Marks.Positions[k];
				SeriesMarks.Position pos3 = bar3.Marks.Positions[k];
				Rectangle rect1 = pos1.Bounds;
				Rectangle rect2 = pos2.Bounds;
				Rectangle rect3 = pos3.Bounds;
				while (Rectangle.Intersect(rect1, rect2) != zero)
					pos2.Custom = true;
					pos2.LeftTop.Y = pos2.LeftTop.Y + 2;
					pos2.LeftTop.X = pos2.LeftTop.X;
				while (Rectangle.Intersect(rect1, rect3) != zero
				       || Rectangle.Intersect(rect2, rect3) != zero)
					pos3.Custom = true;
					pos3.LeftTop.Y = pos3.LeftTop.Y + 2;
Initially it looked like it was working:
However if you scroll it horizontally, the repositioned marks stays stuck on the right bound of the chart. Please see image below:
I have tried to trigger the mark reposition method also on Scroll Event but still the same issue persists.
I'm setting AutoPosition property but doesn't seem to have any effect.
_bar1.Marks.AutoPosition = true;
Thanks in advance!
Re: Marks Overlapping
Post by Pep » Mon Sep 12, 2016 9:41 am
have you tried to refresh the Chart just after the "for" inside the repositionMarks method ?
            Chart1.Chart.Invalidate();
This should make to repaint the Marks.
Post by Pep » Mon Sep 12, 2016 2:14 pm
I've been checking more exhaustively the problem, and just want to give you a better solution to the problem. In order to correctly draw marks at a custom position you should call the RepositionMarks methid at the OnAfterDraw event, but the method has to update the marks and arrow positions to correctly canvas relative position. You should use code similar to the following one (here you should introduce the intersect code and also call the method for each Series) :
        private void RepositionMarks(Steema.TeeChart.Styles.Series series)
            Steema.TeeChart.Styles.SeriesMarks.Position pos;
            series.Chart.AutoRepaint = false;
            for (int i = 0; i < series.Count; i++)
                pos = series.Marks.Positions[i];
                pos.Custom = true;
                pos.LeftTop.Y = series.CalcYPosValue(series.YValues[i] / 2);
                pos.ArrowTo.Y = pos.LeftTop.Y;
                pos.ArrowFrom.Y = pos.LeftTop.Y;
                pos.LeftTop.X = series.CalcXPosValue(series.XValues[i] );
                pos.ArrowTo.X = pos.LeftTop.X;
                pos.ArrowFrom.X = pos.LeftTop.X;
            series.Chart.AutoRepaint = true;
            series.Chart.Invalidate();
XamarinProgrammer
Post by XamarinProgrammer » Tue Sep 13, 2016 3:57 am
Hi Pep,
Firstly thank you for spending time on this. I really appreciate it.
Ok so I have incorporated the codes you have given me but the problem still persists. The mark is positioning well on Y axis however when I call CalcXPosValue it is giving me an x coordinate that is almost out of screen. I am not sure if this has something to do with screen scale or zoom. Bigger problem is that, as I scroll left right, the CalcXPosValue is always giving me the same value (until the particular bar is out of screen) hence the mark is not moving with the bar. I'm thinking maybe because the bar is still rendering, however the method is called on AfterDraw.
Please look at this video to understand what I mean:
https://www.dropbox.com/s/ky7lga58il4uy ... s.mov?dl=0
Post by Pep » Tue Sep 13, 2016 11:58 am
ok, I think the problem could be related on when calcxposvalue and calcyposvalue is done (inside the AfterDraw event). Using the following code all the marks seem to be correctly displayed if these overlap, and also scrolling. Please check the code and if the problem persists let me know so I can send to you a small example with all the files :
        private void repositionMarks()
            bar1.Chart.AutoRepaint = false;
            bar2.Chart.AutoRepaint = false;
            bar3.Chart.AutoRepaint = false;
                pos2.LeftTop.Y = bar2.CalcYPosValue(bar2.YValues[k]);
                pos2.LeftTop.X = bar2.CalcXPosValue(bar2.XValues[k]);
                pos2.Custom = true;
                pos2.ArrowTo.Y = pos2.LeftTop.Y;
                pos2.ArrowFrom.Y = pos2.LeftTop.Y;
                pos2.ArrowTo.X = pos2.LeftTop.X;
                pos2.ArrowFrom.X = pos2.LeftTop.X;
                    pos2.LeftTop.Y += 20;
                    pos2.ArrowTo.Y += 20;
                    pos2.ArrowFrom.Y += 20;
                bar2.Chart.AutoRepaint = true;
                bar2.Chart.Invalidate();
                pos3.LeftTop.Y = bar3.CalcYPosValue(bar3.YValues[k]);
                pos3.LeftTop.X = bar3.CalcXPosValue(bar3.XValues[k]);
                pos3.Custom = true;
                pos3.ArrowTo.Y = pos3.LeftTop.Y;
                pos3.ArrowFrom.Y = pos3.LeftTop.Y;
                pos3.ArrowTo.X = pos3.LeftTop.X;
                pos3.ArrowFrom.X = pos3.LeftTop.X;
                Chart.Header.Text = "No Entra";
                    Chart.Header.Text = "Entra";
                    pos3.LeftTop.Y += 20;
                    pos3.ArrowTo.Y += 20;
                    pos3.ArrowFrom.Y += 20;
                bar3.Chart.AutoRepaint = true;
                bar3.Chart.Invalidate();
        private void Chart_AfterDraw(object sender, Steema.TeeChart.Drawing.Graphics3D g)
            repositionMarks();
