Specific custom y axis labels
TomAgos
Post by TomAgos » Tue Jan 28, 2025 12:13 pm
Hey
we are adding few FastLines to the chart, and for every FastLine we create y axis and attach him to it.
every y axis have Min and Max using the 'SetMinMax' method.
i want only 2 labels on every y axis:
1. the minimum value at the bottom
2. the maximum value at the top
this is what i tried:
       private Axis CreateCustomYAxis(SignalModel signal, double relativePosition)
           var color = ChartDataToZData.MColorToDColor(signal.Color);
           var yAxis = new Axis
               Visible             = false,
               Horizontal          = false,
               Grid                = { Visible = false },
               Labels              = { Font = { Color = color } },
               AxisPen             = { Color = color, Visible = true },
               Ticks               = { Color = color },
               RelativePosition    = relativePosition
           yAxis.SetMinMax(signal.MinOrFactor, signal.MaxOrOffset);
           yAxis.GetAxisDrawLabel += YAxis_GetAxisDrawLabel;
           return yAxis;
         private void YAxis_GetAxisDrawLabel(object sender, GetAxisDrawLabelEventArgs e)
            if (sender is Axis axis) // Cast sender to Axis
                if (e.LabelValue != axis.Minimum && e.LabelValue != axis.Maximum)
                    e.Text = ""; // Hide all other labels
this works fine most of the time. but in some Minimum and maximum values i cant see the minimum label.
for example, when the minimum of the axis is -500 and the maximum is 500, no minimum label.
any suggestions?
Re: Specific custom y axis labels
Post by Marc » Tue Jan 28, 2025 1:33 pm
There are different ways of approaching this but adding customised labels for this controlled intention, rather than a callback, may be an easier way:
        Visible = false,
        Horizontal = false,
      AddCustomLabels(signal.MinOrFactor, signal.MaxOrOffset);
      return yAxis;
    private void AddCustomLabels(double aMin, double aMax)
      tChart1.Axes.Custom[0].Labels.Items.Clear();
      (tChart1.Axes.Custom[0].Labels.Items.Add(aMax, aMax.ToString())).Font.Size = 16;  //optional text enhancement
      tChart1.Axes.Custom[0].Labels.Items.Add(aMin, aMin.ToString());
TomAgos
Post by TomAgos » Wed Jan 29, 2025 7:42 am
This doesnt work:
i hope the image is working..
if not: i still see all the labels... and the minimum and maximum.
and at the first y axis that i add, i dont see any labels
TomAgos
Post by TomAgos » Wed Jan 29, 2025 8:20 am
i also need to update the labels when zooming in and out, and when panning.
the axis label should display the new maximum and minimum according to the zoom and panning, so this should update in run time. ideas?
Post by Marc » Wed Jan 29, 2025 10:51 am
The Chart needs to have calculated the axes before settings items will work, normally a start, once only, repaint resolves that. But anyway if you want to zoom the axes and require a change of labels, then the labels will require updating and the callback should be used. I'll modify the example and post the sample code up here.
Post by Marc » Wed Jan 29, 2025 12:43 pm
There's a TeeChart bug here. Custom axes stats don't correctly update after a zoom (like they do after a scroll/pan). We'll fix it. Thanks for reporting the issue.
https://www.steema.com/bugs/show_bug.cgi?id=2758
Post by Marc » Tue Feb 04, 2025 12:01 pm
as a followup. The issue has been resolved for the next release.
