Customizing Series
Anthony
Customizing Series
Post by Anthony » Tue Jan 25, 2005 9:43 am
Two questions about customizing series:
1) is it possible that not each data point on my series shows up with a pointer, but let's say each 10th data point; the problem is that I have large series of length of 400, so I only see the pointers and no line; is there some increment for pointers ??
2) normally the data points are connected with straight lines; is it possible to present the series as a collection of points; I can realize that by means of the TeeChart Editor, but how to do that in run time ??
Some help would be nice.
Thanks a lot.
Kind regards,
Antoon Koster
WL| Delft Hydraulics
Netherlands
Marjan
Post by Marjan » Tue Jan 25, 2005 9:56 am
Hi.
Re #1 : Yes, it can be done. You can use series GetPointerStyle event to filter series pointers. Example
    private void line1_GetPointerStyle(Steema.TeeChart.Styles.CustomPoint series, Steema.TeeChart.Styles.CustomPoint.GetPointerStyleEventArgs e)
      // Diplay only every 10th pointer
      if (e.ValueIndex % 10 != 0) e.Style = Steema.TeeChart.Styles.PointerStyles.Nothing;
      else e.Style = Steema.TeeChart.Styles.PointerStyles.Circle;
Re #2 : Simply use point series instead of line series. Or hide line series connecting pen by setting lineseries Brush.Visible and LinePen.Visible properties to false:
line1.Brush.Visible = false;
line1.LinePen.Visible = false;
Marjan Slatinek,
Anthony
Post by Anthony » Tue Jan 25, 2005 11:38 am
Thanks for your quick reply.
I just tried your second example, and tried to hide drawing the lines, by means of
but TeeChart still draws the lines in between the data points. Strange ..
The complete code looks like this:
Steema.TeeChart.Styles.Line line;
int iSeries=0;
for (int iPar=0;iPar<noPars;iPar++)
for (int iLoc=0;iLoc<noLocs;iLoc++)
DateTime[] xValues = new DateTime[noTimes];
float[] yValues = new float[noTimes];
line = new Steema.TeeChart.Styles.Line();
line.CustomVertAxis = customAxis[iPar];
// populating series
line.XValues.DateTime = true;
line.Marks.Visible = marksVisible;
line.Pointer.Visible = pointersVisible;
line.Pointer.Style = pointerStyles[iPar];
line.Pointer.VertSize = 3;
line.Color = lineColors[iSeries];
int iWidth = Math.Max(1,iSeries/this.maxColors+1);
line.LinePen.Width = iWidth;
line.Brush.Visible = false;
line.LinePen.Visible = false;
tChart1.Series.Add(line);
DateTime start = new DateTime();
for (int iTime=0;iTime<noTimes;iTime++)
xValues[iTime] = dateTimes[iTime];
yValues[iTime] = gsSeries[iPar,iLoc,iTime];
tChart1.Series[iSeries].Add(xValues,yValues);
tChart1.Series[iSeries].Title =
gsParameters[iPar] + gsLocations[iLoc];
tChart1.BackColor = Color.White;
iSeries++;
noSeries = iSeries;
Any idea what's going wrong ??
Antoon Koster
WL|Delft Hydraulics
Netherlands
Post by Pep » Wed Jan 26, 2005 5:12 pm
Hi Antoon,
are you using the latest Build available on our web site (at the private customers download page ) ?
Using the following code works fine here.
private void Form1_Load(object sender, System.EventArgs e)
	Steema.TeeChart.Styles.Line line1 = new Steema.TeeChart.Styles.Line();
	line1.FillSampleValues();
	line1.Pointer.Visible =true;
	line1.LinePen.Visible =false;
	tChart1.Series.Add(line1);
Anthony
Post by Anthony » Mon Jan 31, 2005 8:38 am
Thanks for your hints, but I think I am missing some details.
If I change my series from tChart1.Series into
Steema.TeeChart.Styles.CustomPoint series;
then I see a method GetPointerStyle().
Do I have to add an event, like
series.GetPointerStyle += new <event handler> <line1_GetPointerStyle).
Is that the way to do that ?
And last question, how can I connect that custom series to my chart. With *normal* series I use tChart1.Series, but how does that work for custom series.
Thanks a lot.
Anthony,
Wl|Delft Hydraulics
Netherlands
Post by Pep » Thu Feb 10, 2005 6:38 pm
Hi Anthony,
yes, you can find one example which shows how to use this event in the Demo Features project included with the installation. Do a search for "pointer style event".
