ASP Examples problem
Sonia
Post by Sonia » Sun Feb 06, 2005 11:22 am
Hi, I have the problem to browse the “ASP server examples” after TeeChartNET1 install.
By ASP Script demo and WebForm demo click I get error “You are not authorized to view this page” HTTP 401.1 - Unauthorized: Logon Failed.
I use Windows 2000 Server.
What is the trouble?
Thanks. Sonia.
Post by Narcís » Mon Feb 07, 2005 8:52 am
Hi Sonia,
This seems to be a IIS configuration problem. Can you create a new webform project an run it properly?
Sonia
Post by Sonia » Tue Feb 08, 2005 7:39 am
Yes. I can.
Post by Narcís » Tue Feb 08, 2005 9:28 am
Hi Sonia,
Using the latest Build 1.1.1769.19457 version (available at our customer download area) works fine here. Are you using this version and running the examples from the program manager TeeChart for .NET entry?
Sonia
Post by Sonia » Tue Feb 08, 2005 10:22 am
Yes, I use this version and examples.
Post by Pep » Tue Mar 01, 2005 3:35 pm
Hi Sonia,
check the permissions of the Examples folders of the TeeChart for Net installation, and make sure these have the ASP.NET account added.
Keynetix
Post by Keynetix » Wed Jun 28, 2006 4:30 pm
Hi.
I also had this problem. The only way I found round it is was to delete the virtual directory in IIS, and setup a new one with the same paths.
