Setting Zoom Rectangle Pattern has no effect.
VH1
Post by VH1 » Thu Oct 13, 2005 12:59 pm
I am using,
TeeChart .NET Version 1.1.1879.21176.
Upon setting the zoom rectangle Pattern color to WHITE, it defaults to using BLACK as its background color.
Please follow the following steps to re-create:
1/ Add a Teechart to a form using the designer. (Dont change any defaults)
2/ Add a Commander toolbar and set the Chart property to the one just placed on the form.
3/ Run the application.
4/ Add a new series to the Teechart using the TeeCahrt Editor.
5/ Test zoom rectangle - the zoom rectangle background color is transparent.
6/ Starting from the Chart tab, navigate to the General tab.
7/ Inside the Zoom tab, press the "Pattern..." button.
8/ Select a SOLID color to something other than WHITE.
9/ Test zoom rectangle - the zoom rectangle background color changes as expected.
10/ Now repeat steps 6-9 but change the color back to WHITE.
11/ Test zoom rectangle - the zoom rectangle background color is always BLACK.
Additionally, the zooming rectangle background color changes to BLACK after a chart has been exported as a .ten file.
Please advise how I can get the zoomng rectangle background color to the default transparent?
VH1
Post by VH1 » Tue Oct 18, 2005 2:39 pm
Ok, after much frustration...
The only way I can get the rectangle back to transparent is to load the .ten file straight after saving, very tedious!!!
VH1
Post by VH1 » Wed Oct 19, 2005 4:46 pm
1.1.2117.41652
Have tested this issue again and it is still present in the new update.
Will this be fixed in the future?
Vaughan
Post by Narcís » Thu Oct 20, 2005 7:20 am
Hi Vaughan,
Yes, we have been able to reproduce it and we are investigating if we can find a solution for it. I'll get back to you if I have some news.
VH1
Post by VH1 » Thu Nov 10, 2005 2:10 pm
Any progress on this issue?
Vaughan
VH1
Post by VH1 » Mon Jan 23, 2006 5:02 pm
An news on this issue yet please, as the workaround is tedious and the loading of a template file creates more problems, which I will raise as a seperate issue.
VH1
Post by Narcís » Tue Jan 24, 2006 9:09 am
Hi Vaughan,
We did some investigation on that and didn't found an easy solution. This issue is already on our defect list to be further investigated and fixed for next releases..
VH1
Post by VH1 » Tue Mar 20, 2007 10:54 am
This still applies in version 1.1.2531.28391?
Post by Narcís » Tue Mar 20, 2007 12:18 pm
Hi VH1,
Yes, we still haven't found a solution for that. Please be aware at this forum for new release announcements and what's being fixed and implemented on them.
Post by Marc » Wed Mar 21, 2007 4:06 pm
Issue resolved and included for next maintenance release.
