HTTP Error 404: Object Not Found
TeeUser
Post by TeeUser » Thu Dec 29, 2005 3:34 pm
Hi Iam trying to open th TeeChart Smaple examples and I get the following error.
Unable to open Web project 'TeeChartForNET'. The file path 'C:\Program Files\Steema Software\TeeChart for .NET v2\Examples\Web\TeeChartNET' does not correspond to the URL 'http://Localhost:/TeeChartForNET'. The two need to map to the same server location. HTTP Error 404: Object Not Found
Any help is appreciated.
Post by Pep » Mon Jan 02, 2006 12:12 pm
do you have IIS installed ?
If so, could you please go to IIS manager, into Default Web Sites, and check that you've an entry named "TeeChartForNet" which points to "F:\Program Files\Steema Software\TeeChart for .NET v2\TeeChartForNET" ?
If you dont have this entry, you should be able to add it manually. However this entry should be added automatically using the installer.
