Stacking areas stacks all the series, is this a bug?
TonyC
Post by TonyC » Wed Jul 26, 2006 4:40 pm
I've got 2 area series and 5 line series in a chart. I want the area series to be stacked. I want the line series to NOT be stacked.
In the design time editor for TeeCharts, I make the appropriate changes to stack the area series. Then when I switch to one of the line series it says that it is stacked. So I set that back to none and switch back to the area series and it says it's not stacked either.
This same behavior happens in my code as well.
			foreach(Steema.TeeChart.Styles.Series series in chart.Series)
				if (series is Steema.TeeChart.Styles.Area)
					Steema.TeeChart.Styles.Area area = (Steema.TeeChart.Styles.Area)series;
					area.MultiArea = Steema.TeeChart.Styles.MultiAreas.Stacked;
				if (series is Steema.TeeChart.Styles.Line)
					Steema.TeeChart.Styles.Line line = (Steema.TeeChart.Styles.Line)series;
					line.Stacked = Steema.TeeChart.Styles.CustomStack.None;
What is going on here?
How do I stack the area series but NOT stack the line series?
I'm running the latest version of TeeCharts for .NET that I installed this morning. Here's the version number: 1.1.2004.16592.
Post by Pep » Mon Jul 31, 2006 10:36 am
Hi Tony,
yes, you're correct, it's a bug, I've added this on our defect list to be considered to fix for the next maintenance releases.
For the moment I've not found a good workaround, if I know one I'll let you know.
TonyC
Thanks Pep!
Post by TonyC » Mon Jul 31, 2006 1:58 pm
When do you expect your next maintenance release?
Post by Narcís » Mon Jul 31, 2006 2:01 pm
Hi TonyC,
We expect to have a new maintenance release ready during next week but we can not tell for sure if a fix for this will be included on it. Please be aware at this forum for the new version release notes.
TonyC
What's the latest?
Post by TonyC » Wed Nov 29, 2006 4:51 pm
Narcís,
I've reviewed the release notes for both v1 and v2 of TeeCharts and I didn't see a fix listed. I also tested the problem on the latest versions and got the same results.
Do you have any idea when this will be fixed?
-TonyC
Post by Narcís » Thu Nov 30, 2006 9:56 am
Hi TonyC,
This issue (TF02011646) hasn't been fixed yet. Unfortunatelly I can't give you a date of when this will be fixed. Please be aware at this forum for new releases announcements.
