Logarithmic scale with small numbers results bad axis labels
Posted: Thu Oct 16, 2008 8:59 pm
by 8739068
I have uploaded an example project called ChartLogrithamicBug It charts 7 point series. 6 are visible and have 1 point in each series. The 7th series has 2 points but the points are made invisible with a transparency = 100.
Here is a picture of what is charted
http://tinyurl.com/4rmvna
on the vertical axis, notice there is no tick marks. Zooming will make some tick marks show up.
1. Why is there no tick marks?
2. Why does panning only pan horizontally and not vertical?
3. How do you post pictures? I tried using the Img tag around the URL and it did not work.
Posted: Fri Oct 17, 2008 9:29 am
by narcis
Hi Mike,
This is because values are very similar and there's no significative differences between them in a logarithimic scale. Same would happen with non-logarithmic axes and a series with a constant y value (all y values being the same), in that case the constant y value would be represented as a single label. In that case, logarithmic labels would be: 1, 10, 100, 1000, etc. Since chart values are lower than 1 no label is plotted. To solve this you can add code below to your example.
tChart1.Axes.Left.Labels.ValueFormat = "#,##0.00";
tChart1.Axes.Left.Increment = 0.001;
This is because left axis minimum and maximum are almost the same you could solve that manually setting axes min. and max. values:
tChart1.Axes.Left.SetMinMax(0, 5);
Putting image's URL between img tags works fine for me:
Not sure I understand
Posted: Fri Oct 17, 2008 12:40 pm
by 8739068
I am surprised that there are no labels on the left axis as you can see in the picture. Shouldn't there at least be 0.0, or the min/max values labeled? Instead it is just blank. That appears to be a bug to me.
Hmmm. Strange. I tried the url in between the tags and when I previewed it did not show the image. Maybe this is a limitation of preview.
Posted: Fri Oct 17, 2008 1:27 pm
by narcis
Hi Mike,
I've added this (TF02013469) to the defect list to be investigated.
Preview also worked fine for me. Notice that I used images URL not entire Picasa page URL. For getting image's URL I right-clicked on it and chose "Copy Image Location" in FireFox, same feature exists in IE.
Posted: Tue Oct 21, 2008 1:03 pm
by narcis
Hi Mike,
As a follow up to the issue above, we have found that a workaround is setting invisible series to non-Active instead of making it transparent, for example:
tChart1.Axes.Left.Logarithmic = true;
tChart1.Axes.Left.MaximumOffset = 50;
for (int i = 0; i < 7; i++)
tChart1.Series.Add(new Steema.TeeChart.Styles.Points());
tChart1[6].Active = false;
//tChart1[6].Color = Color.Transparent;
tChart1[0].Add(12, 0.080688476);
tChart1[1].Add(14, 0.06408694);
tChart1[2].Add(16, 0.050903320);
tChart1[3].Add(18, 0.040405273);
tChart1[4].Add(20, 0.0318860351);
tChart1[5].Add(24, 0.020141601);
tChart1[6].Add(11.4, 0);
tChart1[6].Add(24.6, 1);
Notice that labels problem may be solved using MaximumOffset as shown above.
What is MaximumOffset?
Posted: Tue Oct 21, 2008 1:52 pm
by 8739068
What exactly is the purpose for MaximumOffset and what does it do?
Posted: Tue Oct 21, 2008 2:03 pm
by narcis
Hi Mike
MaximumOffset is the amount of pixels that will be left as a margin at axis maximum position. This property is useful when you dont want the series to display points very close to axis boundaries.
