TreatNulls does not work definitely
awata
Post by awata » Mon Mar 23, 2009 9:15 am
In case where all points are Null and "Series.Pointer.Brush.Color" or "Series.Pointer.Color" has color property. then pointer is displayed.
In case where all points are Null and "Series.Pointer.Brush.Color" or "Series.Pointer.Color" does not have color property then pointer is not displayed.
I think in both case. the pointer should not be displayed.
        private Steema.TeeChart.Styles.Line lineSeries;
            this.tChart1.Axes.Left.SetMinMax(0, 100);
            this.lineSeries = new Steema.TeeChart.Styles.Line(this.tChart1.Chart);
            this.lineSeries.Pointer.Visible = true;
            this.lineSeries.TreatNulls = Steema.TeeChart.Styles.TreatNullsStyle.DoNotPaint;
            lineSeries.Pointer.Brush.Color = Color.YellowGreen;
            lineSeries.Pointer.Color = Color.YellowGreen;
            this.CreateArrays();
        int length = 60;
        private void CreateArrays()
            for (int i = 0; i < length; i++)
                this.lineSeries.Add(DateTime.Now.AddSeconds(i), null);
teechart ver.3.5.3330.21113
VS2005 SP1
Post by Yeray » Mon Mar 23, 2009 11:24 am
Hi awata,
This is working as expected because internally, null points are normal points but without color.
Could you tell us what are you trying to achieve and we'll see if we can suggest you a satisfactory way to do it?
