Maximum Offset Issue
Amol
Post by Amol » Fri Mar 27, 2009 8:04 am
We are facing an issue that whenever we are changing the mamimum offset value for left axis then number of labels and values of label change and hence we want to retrieve those changed values which we see on the display area of t-Chart. We are attaching the required snaps of the problem which we are facing at the upload page.
Post by Yeray » Fri Mar 27, 2009 10:19 am
Hi Amol,
I'm not sure to understand why are you changing MaximumOffset and not directly your Maximum, if you are going to check the maximum in a future.
Anyway, you always can the value of the axis at its end position:
 tChart1.Axes.Left.CalcPosPoint(tChart1.Axes.Left.IEndPos)
