hotspot_GetHTMLMap
norman
hotspot_GetHTMLMap
Post by norman » Fri Mar 27, 2009 5:29 pm
When does hotspot_GetHTMLMap fire? I know it fires for each point but when in the sequence of things i.e. only the first time data is added? I've added a hotspot tool to my chart to customise tooltips that appear over points and and I've also added code to restore my chart between postbacks (as demonstrated in the teechart examples). Things worked fine however I have another button on my page that I've used to add annotations to the chart and I need hotspot_GetHTMLMap to fire (as I'm adding new poly areas to mapelements) but it doesn't seem to second time around (i.e. after I'e restored the chart from session). The tooltips that were working disappear. Is its possible to call this event programatically?
[Since posting this I've found that if I remove the existing hotspot tool and add a new one things work as expected. I placed this code in the click event of the button that added the annotations, after the call to redraw the chart. It seems to work but I'm not exactly sure why? :?]
Norman
Post by Marc » Tue Mar 31, 2009 11:15 am
Hello Norman,
The hotspot map should correctly re-assign hotpsots to the page map everytime a pageload (page refresh) is called permitting the map to re-align with new data. If that isn't happening then there may be a procedural problem with the Chart/Hotspot tool load.
If that is the case, does the old hotspot map remain active between page loads? (ie. reporting hits where the first pageload hotspots were). If you view the page source, has the html map disappeared? Tag:
HTML <MAP name="MAP .... etc
If you have a small sample project that displays the problem, that you could send us, it would help us debug the problem.
With thanks.
norman
Post by norman » Tue Mar 31, 2009 4:04 pm
Hi Marc,
Apologies but I couldn't post the complete sample project but see below for an illustration of what's going on. Essentially cmdPlotData adds data to the chart and cmdShowAnnotations shows/hides annotations.
The page containing the chart is actually a user control (i.e. .ascx) which is added dynamically to a web page at runtime. The user control supports partial rendering which may have something to do with it?
To answer:
No, the map is still there.
If I leave out the line:
cmdShowAnnotations_Click(sender, e)
in the cmdPlotData_Click event then the tooltips continue to work. If I include this line then I have to reinitialize the hotspot tool.
Private annotations As New Dictionary(Of Integer, Steema.TeeChart.Tools.Annotation)
Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
   InitializeHotSpotTool
   If Not Page.IsPostBack Then
      ' Remove existing session stored Chart
      Session.Remove("tmpChart")
      ' Plot data
      cmdPlotData_Click(sender, e)
   Else
      ' Restore from session if the postback was caused by a control on another user control or if the chart data doesn't need to change
      Dim ctrl As Control = GetPostBackControl(Me.Page) ' returns control that caused postback
      If Not (ctrl Is Nothing) AndAlso Not (Session("tmpChart") Is Nothing) Then
         If Not ctrl.ClientID.StartsWith("myParentCtrlPrefix") OrElse _
            ctrl.ID <> "cmdPlotData" AndAlso _
            ctrl.ID <> "cmdSomeOtherButton" Then
            Dim tmpChart As MemoryStream = New MemoryStream()
            ' Retrieve the session stored Chart
            tmpChart = CType(Session("tmpChart"), MemoryStream)
            tmpChart.Position = 0
            ' Import saved Chart
            WebChart.Chart.Import.Template.Load(tmpChart)
         End If
      Else
         ' Plot data
      End If
   End If
Protected Sub cmdPlotData_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles cmdPlotData.Click
   ' Get new data from database
   ' Add chart series and chart data
   ' Not shown for brevity
   ' Draw annotations
   cmdShowAnnotations_Click(sender, e) ' if omitted tooltips continue to appear
   ' Export Chart to a MemoryStream template
   WebChart.Chart.Export.Template.Save(tmpChart)
   ' Save template to a Session variable
   Session.Add("tmpChart", tmpChart)
Protected Sub cmdShowAnnotations_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles cmdShowAnnotations.Click
   ' Get data from database
   ' Remove any existing chart annotation tools
   ' For each row of data add new chart annotation tool and populate annotations dictionary object
   Dim bmp As Drawing.Bitmap = WebChart.Chart.Bitmap(w, h)
   InitializeHotSpotTool ' if omitted hotspots dont work
Protected Sub WebChart_AfterDraw(ByVal sender As Object, ByVal g As Steema.TeeChart.Drawing.Graphics3D) Handles WebChart.AfterDraw
   ' Iterate annotations and position accordingly using pixel coordinates
   For Each kvp As KeyValuePair(Of Integer, Steema.TeeChart.Tools.Annotation) In annotations
   Next
Private Sub hotspot_GetHTMLMap(ByVal sender As Steema.TeeChart.Tools.SeriesHotspot, ByVal e As Steema.TeeChart.Tools.SeriesHotspotEventArgs)
   ' Create mouseover hints for series data
   Dim XVal As String = e.PointPolygon.Title
   XVal = Date.FromOADate(e.Series.XValues.Value(e.PointPolygon.ValueIndex)).ToString()
   e.PointPolygon.Title = "Date/Time: " & XVal & vbCrLf & _
   "Value: " & e.Series.YValues.Value(e.PointPolygon.ValueIndex).ToString()
   ' Create mouseover hint for each annotation
   If ((e.Series Is WebChart.Chart(0)) AndAlso (e.PointPolygon.ValueIndex = 0)) Then
      Dim mapElements As String = String.Empty
         ' Add to mapElements remembering about lead "<"
      Next
      If mapElements <> String.Empty Then
         CType(sender, Steema.TeeChart.Tools.SeriesHotspot).MapElements = mapElements
      End If
   End If
Private Sub InitializeHotSpotTool()
   ' Iterate chart tools and remove any existing hotspot tools
   ' Add hotspot tool
   Dim seriesHotspotTool As New Steema.TeeChart.Tools.SeriesHotspot(ch)
   With seriesHotspotTool
      .HelperScript = Steema.TeeChart.Tools.HotspotHelperScripts.Annotation
      .HotspotCanvasIndex = 499
      .MapAction = Steema.TeeChart.Styles.MapAction.Script
      .MapElements = ""
   End With
   AddHandler seriesHotspotTool.GetHTMLMap, AddressOf hotspot_GetHTMLMap
Norman
