Missing Data in the graph
Mahadevan
Post by Mahadevan » Tue Mar 31, 2009 8:15 pm
we have a problem with the graph generated from TeeChart.
In the graph generated, a few bars are missing.
To reproduce the problem, please use the file TeeChartMissingBars.zip
(A standalone windows application uploaded to http://www.steema.net/upload/Default.aspx)
Please let me know if there is any solution to the problem.
Thanks And Regards,
Mahadevan
Post by Yeray » Wed Apr 01, 2009 8:32 am
Hi Mahadevan,
This is a known bug in the wish list that we will try to fix asap (TF02013516).
Mahadevan
Post by Mahadevan » Fri Apr 03, 2009 7:09 am
Can you let me know the tentative time by which the solution for this would be available, so that we can plan our things accordingly.
Thanks And Regards,
Mahadevan
Post by Narcís » Fri Apr 03, 2009 11:14 am
Hi Mahadevan,
Recently we fixed some similar issue but it seems some special cases remained uncovered. I can't give an estimate date at the moment. I recommend you to be aware at this forum or subscribe to our RSS news feed for new release announcements and what's fixed on them.
THoMaSiN
Post by THoMaSiN » Fri Apr 03, 2009 8:08 pm
I have this problem very often as well, but never been able to reproduce consistently enough to send you a project, please increase the priority if you can !!
Mahadevan
Post by Mahadevan » Mon May 18, 2009 7:48 am
Can you please let me know when a fix for this would be available?
Post by Narcís » Mon May 18, 2009 9:26 am
Hi Mahadevan,
I've just checked that this has been fixed for the next TeeChart for .NET v3 maintenance release due out imminently.
Mahadevan
Post by Mahadevan » Wed May 20, 2009 12:06 pm
Seems like the problem is not fixed in the release 3.5.3425.20245.
(Issue is not mentioned in the release notes and also when tried with the above mentioned release, problem persists)
Can you let me know the time line by the fix would be available?
Thanks And Regards,
Mahadevan
Post by Narcís » Wed May 20, 2009 2:15 pm
Hi Mahadevan,
I've just checked that the TeeChartMissingBars project you sent works fine for me here using build 3.5.3425.20245 and fails using previous release. Could you please check that your project's TeeChart.dll has been correctly updated?
