Bug on map series
Pujol1986
Bug on map series
Post by Pujol1986 » Tue May 26, 2009 11:47 am
Hello, I've found a bug while I was drawing polygons.
If I draw more than 13 polygons, the polygons don't draw on the position that I want.
there is an example image with 13 polygons on the screen:
this map was created with this simple code:
        For i As Integer = 1 To 13
            Dim X() As Integer = {i, i + 1, i + 1, i}
            Dim Y() As Integer = {1, 1, 2, 2}
            Map2.AddShape(X, Y, "")
        Next i
and this is how the map looks like when I change the 13 for a 14 in the For loop:
there is the code:
        For i As Integer = 1 To 14
        Next i
like you can see, I can't create more than 13 polygons because there is an error with the following polygons.
My release is:
Release Notes 12th February 2009
TeeChart.NET version 3
Build 3.5.3330.21114
Post by Yeray » Wed May 27, 2009 11:31 am
Hi Pujol,
Yes, you are right. I've added it to the wish list to be fixed asap (TF02014189).
Note that in the meanwhile, you could add the polygons manually as in the following example that works fine for me here:
Steema.TeeChart.Styles.Map map1 = new Steema.TeeChart.Styles.Map(tChart1.Chart);
Steema.TeeChart.Styles.PolygonList shapes = new Steema.TeeChart.Styles.PolygonList(map1);
Steema.TeeChart.Styles.Polygon P1;
Random rnd = new Random();
for (int i = 0; i < 20; i++)
    P1 = new Steema.TeeChart.Styles.Polygon(shapes, tChart1.Chart);
    P1.Add(i, 1);
    P1.Add(i + 1, 1);
    P1.Add(i + 1, 2);
    P1.Add(i, 2);
    map1.Shapes.Add(P1);
    map1.Shapes[i].Z = rnd.Next();
    map1.Shapes[i].Text = "";
Pujol1986
Post by Pujol1986 » Thu May 28, 2009 9:58 am
Hello Yeray,
I'm using this code in VB.net:
        For i = 1 To 20
            Dim P1 = New Steema.TeeChart.Styles.Polygon(TChart1.Chart)
            P1.Add(i, 1)
            P1.Add(i + 1, 1)
            P1.Add(i + 1, 2)
            P1.Add(i, 2)
            Map1.Shapes.Add(P1)
            Map1.Shapes(i - 1).Z = 0.125
            Map1.Shapes(i - 1).Text = ""
        Next i
And I have the error NullReferenceException in line Map1.Shapes(i - 1).Z = 0.125
I think that this would be because the line Map1.Shapes.Add(P1) is not working well.
can you help me please? Is something wrong in the code?
Post by Sandra » Thu May 28, 2009 10:18 am
Hello Pujol1986,
Please, check that next example works fine:
Form_Load:
 Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        InitializeChart()
InitializeChart:
   Private Sub InitializeChart()
        Dim map1 As Steema.TeeChart.Styles.Map = New Steema.TeeChart.Styles.Map(TChart1.Chart)
        Dim shapes As Steema.TeeChart.Styles.PolygonList = New Steema.TeeChart.Styles.PolygonList(map1)
        Dim P1 As Steema.TeeChart.Styles.Polygon
        Dim rnd As Random = New Random()
        Dim i As Integer
        For i = 0 To 20
            P1 = New Steema.TeeChart.Styles.Polygon(shapes, TChart1.Chart)
            P1.Add(i, 1)
            P1.Add(i + 1, 1)
            P1.Add(i + 1, 2)
            P1.Add(i, 2)
            map1.Shapes.Add(P1)
            map1.Shapes(i).Z = rnd.Next()
            map1.Shapes(i).Text = ""
        Next i
I hope that will helps.
Pujol1986
Post by Pujol1986 » Thu May 28, 2009 10:35 am
it works fine.
Thanks Sandra :wink:
Re: Bug on map series
Post by Yeray » Thu Jun 25, 2009 9:35 am
Hi Pujol1986,
As an update, I'd like you to know that we've just closed the issue (TF02014189) for v2009 disabling the AddShape method by making it private and adding two new Add methods to the map series:
public int Add(double[] X, double[] Y, double Z, string Text)
public int Add(int[] X, int[] Y, int Z, string Text)
So with the next v2009 maintenance release, this should work fine:
     Map map1 = new Map(tChart1.Chart);
     for (int i = 0; i < 24; i++)
       int[] X = { i, i + 1, i + 1, i };
       int[] Y = { 1, 1, 2, 2 };
       map1.Add(X, Y, i, "");
Pujol1986
Post by Pujol1986 » Thu Jun 25, 2009 10:37 am
Thanks for the info.
