Set minimum major tick count on axis
Alain Bolduc
Post by Alain Bolduc » Tue May 26, 2009 2:48 pm
Hi, is it possible to set a minimum major tick count on an axis?
I am falling in a situation where I get the following graph:
http://picasaweb.google.com/lh/photo/rO ... directlink
As you can see, there is only one label on the bottom axis, which we believe is unacceptable.
Note that if I apply a zoom, I will get something that makes much more sense (sorry the image is a little truncated on the right side..) :
http://picasaweb.google.com/lh/photo/C2 ... directlink
Is there a way to set a minimum number of major ticks?
Thanks!
Post by Narcís » Wed May 27, 2009 11:29 am
Hi marvin966,
The easiest way I can think of is setting axes Increment, for example:
			tChart1.Axes.Bottom.Increment = 0.1;
By default it's set to zero, which mean it's automatic and tries to plot as many labels as can be fitted in the axis. Setting increment to any value TeeChart will try to draw labels in that increment provided they don't overlap otherwise it will use the minimum increment were labels don't overlap.
Alain Bolduc
Post by Alain Bolduc » Tue Jun 02, 2009 3:54 pm
hi Narcis,
I am afraid this solution does not work for me.
See what I get when I zoom to a certain factor:
http://picasaweb.google.ca/lh/photo/68l ... directlink
Notice that there is NO major ticks on the bottom axis, which is even worse than the initial situation.
What I would like to do is to set, for example, 3 as the minimum amount of major ticks, to avoid situations like this one. The graph should automatically adjust the increment.
Thanks!
Post by Yeray » Wed Jun 03, 2009 7:56 am
Hi marvin966,
Probably this will be due to your chart's setup. So it will be helpful if you could send us a simple example project we can run "as-is" to reproduce the problem here.
