Is it possible to make chart axis like on image?
petro
Post by petro » Mon Jun 08, 2009 10:39 am
Is it possible to implement two types of labels for one chart axis like on image bellow(red rectangle)?
I need two axis labels, one for longer period and second for shorter period.
If image didn't appear:
http://piccy.info/view/c1fbbd7a689b18b5 ... 1cc7e0442/
I use the TeeChart 3.5.
Post by Yeray » Mon Jun 08, 2009 11:44 am
Hi petro,
The axes weren't thought to be drawn like you want but you could try using top axis to display one labels and bottom axis to display the others:
            Error error1 = new Error(tChart1.Chart);
            Random rnd = new Random();
            error1.XValues.DateTime = true;
            for (int i = 0; i < 50; i++)
                error1.Add(DateTime.Now.AddDays(i).ToOADate(), rnd.Next(10)+ 25, rnd.Next(5)+20);
            error1.HorizAxis = HorizontalAxis.Both;
            tChart1.Axes.Bottom.Labels.DateTimeFormat = "dd";
            tChart1.Axes.Bottom.Ticks.Length = 5;
            tChart1.Axes.Bottom.TickOnLabelsOnly = true;
            tChart1.Axes.Bottom.MinorTicks.Visible = false;
            tChart1.Axes.Top.Labels.DateTimeFormat = "MMMM";
            tChart1.Axes.Top.Ticks.Length = 30;
            tChart1.Axes.Top.OtherSide = false;
            tChart1.Axes.Top.TickOnLabelsOnly = true;
            tChart1.Axes.Top.MinorTicks.Visible = false;
petro
Post by petro » Mon Jun 08, 2009 1:59 pm
9348257 wrote:Hi petro,
Thank's for solution.
I'll experiment with CustomAxis, so I think I can get appropriate result.
Post by Yeray » Mon Jun 08, 2009 2:38 pm
petro wrote:I'll experiment with CustomAxis, so I think I can get appropriate result.
Here note that you won't be able to assign more than one axis as horizontal axis for the same series. Only with the default top and bottom axis it is possible with:
