Change SeriesType at Runtime
andreask
Post by andreask » Mon Feb 23, 2004 3:24 pm
Hallo
I change the SeriesType with the following codesnipet
tmp := dbChart.Series[0];
ChangeSeriesType(tmp, TBarSeries);
The ChartListbox notifies the new style. In the Charteditor I can see the old Values. But I cannot see the serie. What I am doing wrong?
Post by Pep » Tue Feb 24, 2004 12:11 pm
Hi Andreas,
strange, it works fine here using the TeeChart Pro v6.01. I've post one example to the steema.public.attachments newsgroups. Could you please download it and test if it works fine for you ?
andreask
Post by andreask » Tue Feb 24, 2004 2:26 pm
Hi Pep,
Thanks for the quick answer. The sample project works fine for me to (Version 5.02). I have found the error. After changing the seriestype my series lost the connection to the custom axis. I have created a customvertaxis with property otherside := true which shows datetimes. The left axis shows integers, so values < 1 i don't see. The chart has done his work well but I couldn't see it.
Best regards
Andreas
