nisbus
Post
by nisbus » Wed Apr 04, 2007 2:45 pm
I'm plotting multiple BarSeries on a chart, each bar has a single Yvalue and a text X value.
I have tried two different methods
ChartSeries.AddXY(Value,Date,DisplayName)
ChartSeries.AddY(Value,DisplayName)
Note: the date in this case is always the same.
In both cases I get multiple bars but the bottom axis only shows the displayname of the first series.
How can I get them to display each bars displayname on the bottom axis?
Thank you,
nisbus
Post
by Narcís » Wed Apr 04, 2007 2:48 pm
Hi nisbus,
Yes, this is TeeChart's default behaviour. In that case you should use custom labels as shown in the All Features\Welcome!\Axes\Labels\Custom labels example at the new features demo. You'll find the demo at TeeChart's program group created by the binary installer.
nisbus
Post
by nisbus » Wed Apr 04, 2007 3:47 pm
Ok, I used the method from the demo and this is a small test:
var
ser : TChartSeries;
Ser := TBarSeries.Create(Self);
Ser.Name := 'Ser'+IntToStr(Chart1.SeriesCount);
Ser.ParentChart := Chart1;
Ser.Title := 'yes';
Ser.AddXY(Chart1.SeriesCount,Chart1.SeriesCount,Ser.Title);
Chart1.Axes.Bottom.Items.Add(Chart1.SeriesCount,'yes'+IntToStr(Chart1.SeriesCount));
The problem with this is that the labels don't align with the bars so when I have 4 bars the labels are nowhere near the bottom of the bar.
thanks,
nisbus[/code]
Post
by Pep » Wed Apr 11, 2007 7:42 am
in that case you sould use similar code to the following one :
procedure TForm1.BitBtn1Click(Sender: TObject);
var
ser : TChartSeries;
Ser.Title := 'yes';
(Ser as tBarSeries).MultiBar:=mbNone;
(Ser as tBarSeries).BarWidthPercent:=5;
