CCI Function gives Exception
cdn
Post by cdn » Wed Oct 17, 2007 8:38 am
Hi:
The CCI function gives exception if the datapoints exceed 195. I am enclosing the stack trace for your reference. Could you please let us know any workaround etc.?
The count = 195
CCI - Start, end64.0,80.0, 3,3
CCI - 195
The count = 197
CCI - 197
Exception in thread "AWT-EventQueue-0"  java.lang.ArrayIndexOutOfBoundsException: 196
	at com.steema.teechart.functions.CCI.addPoints(CCI.java:130)
	at com.steema.teechart.styles.Series.addValuesFrom(Series.java:1022)
	at com.steema.teechart.styles.Series.fillFromDataSource(Series.java:2347)
	at com.steema.teechart.styles.Series.checkDataSource(Series.java:2388)
	at com.steema.teechart.styles.Series.setDataSource(Series.java:2287)
	at StockFrame.cciFunction(StockFrame.java:2693)
	at StockFrame.chartFunctionIndicators(StockFrame.java:1865)
	at StockFrame.createFrame(StockFrame.java:3496)
	at StockFrame.cbSInds_actionPerformed(StockFrame.java:516)
	at StockFrame_cbSInds_actionAdapter.actionPerformed(StockFrame.java:3934)
	at javax.swing.JComboBox.fireActionEvent(Unknown Source)
	at javax.swing.JComboBox.setSelectedItem(Unknown Source)
	at javax.swing.JComboBox.setSelectedIndex(Unknown Source)
	at StockFrame.cbBSymbols_actionPerformed(StockFrame.java:380)
	at StockFrame_cbBSymbols_actionAdapter.actionPerformed(StockFrame.java:3901)
	at javax.swing.plaf.basic.BasicComboPopup$Handler.mouseReleased(Unknown Source)
	at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
	at java.awt.Component.processMouseEvent(Unknown Source)
	at javax.swing.JComponent.processMouseEvent(Unknown Source)
	at javax.swing.plaf.basic.BasicComboPopup$1.processMouseEvent(Unknown Source)
	at java.awt.Component.processEvent(Unknown Source)
	at java.awt.Container.processEvent(Unknown Source)
	at java.awt.Component.dispatchEventImpl(Unknown Source)
	at java.awt.Container.dispatchEventImpl(Unknown Source)
	at java.awt.Component.dispatchEvent(Unknown Source)
	at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
	at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
	at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
	at java.awt.Window.dispatchEventImpl(Unknown Source)
	at java.awt.EventQueue.dispatchEvent(Unknown Source)
	at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
	at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
	at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
	at java.awt.EventDispatchThread.run(Unknown Source)
Any insights are appreciated. Thanks.
best regards,
Post by Narcís » Wed Oct 17, 2007 9:15 am
Hi cdn,
Could you please send us a simple example project we can run "as-is" to reproduce the problem here?
Thanks in advance!
cdn
Post by cdn » Thu Oct 18, 2007 8:37 am
Hi:
I wouldn't able to give you a project. What I can give is the data points? Then, you can try it out and let me know what happens. If that is ok, please let me know. Thanks.
best regards,
Post by Narcís » Thu Oct 18, 2007 9:21 am
Hi cdn,
Please notice that your current project is not necessary, just a simple example project we can run "as-is" would be enough to reproduce the problem here. However, if this is not possible, then yes please, send us the data and we will try to reproduce the issue.
cdn
Post by cdn » Fri Oct 19, 2007 8:16 am
Hi:
We have uploaded the file "cci-dataset.txt". This has 201 datapoints. Let us know if you have any questions. Thanks.
best regards,
Post by Marc » Mon Oct 22, 2007 2:09 pm
Thankyou for sending throught the sample data. We have found a problem on calculating set size with the CCI function. That has been corrected and the fix will be included in the next maintenance release.
