Is it possible for TAreaSeries to display in three color ?
nileiqi
Post by nileiqi » Fri Feb 22, 2008 5:41 am
I am try to use TAreaSeries in three different colour, the X axis is based on date & time, then there are three different time frames, in each time frame, I need TAreaSeries in different colors. Is it possible ? thanks.
Daniel
Post by Yeray » Fri Feb 22, 2008 9:12 am
Hi Daniel,
You could set series' property "ColorEachPoint" to true and then assign the desired color to each point. Here is an example:
var i, FirstRange, SecondRange: Integer;
  Series1.ColorEachPoint := true;
  Series1.FillSampleValues(30);
  Series1.XValues.DateTime := true;
  Chart1.Draw;
  FirstRange := 10;
  SecondRange := 20;
  for i:=0 to FirstRange-1 do
    Series1.ValueColor[i]:= RGB(176,0,0);
  for i:=FirstRange to SecondRange-1 do
    Series1.ValueColor[i]:= clRed;
  for i:=SecondRange to Series1.Count-1 do
    Series1.ValueColor[i]:= rgb(255,100,100);
