Samples using VB.NET
Jeff Motter
Post by Jeff Motter » Thu Jul 08, 2004 3:51 pm
Are there any samples for VB.NET? When I installed, there is only C# samples?
Jeff
Post by Pep » Thu Jul 08, 2004 7:03 pm
Hi Jeff,
the Demo Features project has been done in C# code, but you should be able to translate to VB.Net code (very similar code <g>). Also, you can find some ASP.Net examples (VB.Net code) under :
C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET
If you need any help to translate something let us know and we'll try to help you as soon as possible.
Post by Narcís » Fri Jul 09, 2004 7:33 am
Hi Jeff,
you can also try the following link to convert from C# to VB.
http://www.kamalpatel.net/ConvertCSharp2VB.aspx
