Dynamically generating the charts
Please see the prior communication below by scrolling down. I am posting here for prompt reply.
When i use
Panel2.Controls.Add(TChart1) to define parent for the chart, i get the following compilation error. It could be because i am defining these charts as an array of Chart objects and the size of the array of these Chart objects is defined at runtime (after reading certain parameters from a file). So, I am not able to use 'Withevents' for the Chart as the VS 2005 complaining that 'Withevents' can not be used with array of objects.
If i try to create individual chart objects within the calling function, compiler says that i can not use 'Withevents' with the local variables.
So, the real question is how can i define as many chart objects as i need at the runtime. If you have any example code, please share.
Error 1 Value of type 'Steema.TeeChart.Chart' cannot be converted to
'System.Windows.Forms.Control'.
-Prototype\Form1.vb
101 40 TeeChart-Prototype
Please suggest what i should do.
Supriya
Newsgroups: steema.private.support.teechart.dotnet
Sent: Wednesday, December 10, 2008 2:19 AM
Subject: Re: Dynamically generating charts
> Try this:
> Hope this helps!
> Best Regards,
> Narcís Calvet
> Steema Support Central
> http://support.steema.com
> "Important note: If you are a TeeChart registered customer, please post
> your support questions at Steema's Support monitored Forums for customers:
> http://support.steema.com for a prompter reply."
> <asupriya@xxx.xxx> wrote in message
> news:Pa%23NYYpWJHA.1896@TEEPC.Steema.local...
>> Hi,
>> I need to generate charts dynamically based on the parameters that is
>> read from a file. When i tried to do it in the following way, I get an
>> error at at the .parent setup property. Can you please help me?
>> Below is my code. ChartLegends is an array of legends to be posted. There
>> needs to be one series per chart and each series should be present in the
>> legend.
>> Thanks,
>> Supriya
>> For i = 0 To chartLegends.Length - 2
>> myFastLine(i) = New Steema.TeeChart.Styles.FastLine
>> TChart1(i) = New Chart
>> TChart1(i).Page.MaxPointsPerPage = 1000
>> TChart1(i).Page.ScaleLastPage = False
>> 'Me.Panel2.Controls.Add(Me.TChart1(i))
>> 'Panel2 = CType(Panel2, Steema.TeeChart.IChart)
>> TChart1(i).Parent = Panel2
>> TChart1(i).Width = Panel2.Width
>> TChart1(i).Height = 100
>> 'TChart1(i).Page.Current = 0
>> myFastLine(i).Title = chartLegends(i + 1)
>> myFastLine(i).ColorEach = True
>> 'myFastLine(i).Color = Color.FromArgb(333 * i)
>> TChart1(i).Series.Add(myFastLine(i))
>> myFastLine(i).DrawAllPoints = True
>> 'myFastLine(i).TreatNulls =
>> Steema.TeeChart.Styles.TreatNullsStyle.Skip
>> Next
When i use
-Prototype\Form1.vb
Supriya
> Try this:
> Hope this helps!
> Best Regards,
> Narcís Calvet
>> Hi,
>> legend.
>> Thanks,
>> Supriya
>> Next
Hi Supriya,
In that case you can do something like this:
Hope this helps!
Public Class Form1
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
InitializeChart()
Private WithEvents MyChart As Steema.TeeChart.TChart
Private panels() As Panel = New Panel(5) {}
Private Sub InitializeChart()
For i As Integer = 0 To panels.Length - 1
panels(i) = New Panel
MyChart = New Steema.TeeChart.TChart()
Me.Controls.Add(panels(i))
panels(i).Location = New Point(150 * i, 0)
panels(i).Width = 150
panels(i).Height = 100
panels(i).Controls.Add(MyChart)
MyChart.Dock = DockStyle.Fill
MyChart.Series.Add(New Steema.TeeChart.Styles.Line())
MyChart(0).FillSampleValues()
AddHandler MyChart.AfterDraw, AddressOf MyChart_AfterDraw
'You can typecast panel's controls like this:
CType(panels(i).Controls.Item(0), Steema.TeeChart.TChart).Legend.Visible = False
CType(panels(i).Controls.Item(0), Steema.TeeChart.TChart).Header.Visible = False
Next
Private Sub MyChart_AfterDraw(ByVal sender As Object, ByVal g As Steema.TeeChart.Drawing.Graphics3D)
g.TextOut(20, 10, "hello!")
End Class
One more issue.
My file typically contains 5000 milli seconds worth of data with 10 ms interval for various frequency. This gives a huge number of points for each of the frequency.
I plan to use the fastline series; but, i need to provide a long scrollable chart for the user to look at the data (possibly each point) and scrolls the chart (not paging the chart, but actually scrolling the chart data) to see more.
Can you suggest me how i can set the chart dimensions such that my charts are displayed with enough details and with automatic Horizontal scroll bars? When i try to set the dock property of the chart to 'Fill' to the panel and set the panel's dock property 'Fill' to the form, i am getting a very squeezed display that displays 0ms to 5000ms in the width of the form without the scroll bars.
Any suggestions will be appreciated.
Hi asupriya,
You can get the number of points displayed in a chart like this I explained here:
http://www.teechart.net/support/viewtopic.php?t=8931
You can use horizontal scrollbar like in the example Pep posted on this thread:
http://www.teechart.net/support/viewtopic.php?t=1924
Please bear in mind that the maximum rate of points that can be drawn is one point per pixel so you may also want to check ChartRect's dimensions:
Finally you may also be interested in DownSampling function as shown in the All Features\Welcome !\Functions\Extended\Reducing number of points in the features demo, available at TeeChart's program group. It may be also worth having a look at the All Features\Welcome !\Speed\Fast Line Speed DrawAll
Hope this helps!
tChart1.Draw();
int w = rect.Width;
int h = rect.Height;
Hope this helps!
Thanks alot for the suggestions.
Is there anyway i can access the chart objects that are dynamically created as you suggested above? I need to optionally synchronize the curserTool objects on each of these charts (as shown in the Welcome !\Tools\Cursor\Synchronizing Two example).
Also, these chart objects are arranged vertically and I need to align all of them such that their X-values are perfectly aligned vertically. When i set myChart.position to have same X position, its aligning not the y-axis so that X-values get aligned. This problem becomes obvious when you have different Y-axis value range on each of the charts (for example chart 1 with two digit values, chart 2 has 4-digit values, it will push the y-axis to the right on the chart 2).
Hi asupryia,
Yes, you can use them as shown in the example I posted, I also extended it with CursorTool:
About aligning charts, please read this:
http://www.teechart.net/support/viewtopic.php?t=3034
Hope this helps!
InitializeChart()
Dim MyCursor As New Steema.TeeChart.Tools.CursorTool(MyChart.Chart)
CType(CType(panels(i).Controls.Item(0), Steema.TeeChart.TChart).Tools.Item(0), _
Steema.TeeChart.Tools.CursorTool).XValue = 5
Steema.TeeChart.Tools.CursorTool).YValue = 5
Next
Hope this helps!
I have at least 15 chart objects (there can be as many as 128 chart objects in the worst case scenario) to sync the cursor. CType'ing every time is VERY very slow and after about 5 charts, the performance is almost unacceptable.
Is there any other way of keeping track of these chart objects?
regards
regards
Hi asupriya,
Of course, you could also access CursorTools directly:
''You can typecast panel's controls like this:
'CType(panels(i).Controls.Item(0), Steema.TeeChart.TChart).Legend.Visible = False
'CType(panels(i).Controls.Item(0), Steema.TeeChart.TChart).Header.Visible = False
MyChart.Legend.Visible = False
MyChart.Header.Visible = False
MyCursor.XValue = 5
MyCursor.YValue = 5
MyCursor.XValue = 5
'CType(CType(panels(i).Controls.Item(0), Steema.TeeChart.TChart).Tools.Item(0), _
' Steema.TeeChart.Tools.CursorTool).XValue = 5
' Steema.TeeChart.Tools.CursorTool).YValue = 5
Next
I should have been more specific.
I already assign the cursortool in the way you suggested. However, the problem is during the cursorTool1.Change event handling. My code is as follows. It takes about 20-30 sec to change surser position on all the 15 charts. Please suggest a better alternative.
Couple more questions:
1. I am experimenting with the same data used in the dynamic generation of each chart for each of the data series with single chart and multiple custom left axis option. Each of the series has its own custom left axis on a single chart object. The intention is that this method would be much more faster than the previous method where you generate as many charts as the distinct series. But, to my surprise, this method of single chart with multiple custom left charts is much slower than the multiple charts method (keeping the rest all the same - series, data, etc.). Can you please comment on it? Below is the snippet of code.
2. Other question is: How can i change the thickness of the myfastline(i) in the above code?
Private Sub cursorTool1_Change(ByVal sender As Object, ByVal e As Steema.TeeChart.Tools.CursorChangeEventArgs) Handles cursorTool1.Change
ChartStatusLbl.Text = "Time = " & e.XValue & " Y = " & e.YValue
Dim i As Int32
For i = 0 To numCharts - 1
CType(CType(Panel2.Controls.Item(i), Steema.TeeChart.TChart).Tools.Item(0), Steema.TeeChart.Tools.CursorTool).XValue =e.XValue
Next
If (br.BaseStream.Position = data.endptr) Then
ReDim chartLegends(numCharts - 1)
ReDim myFastLine(numCharts - 1)
Dim chartWidth As Int32 = (br.BaseStream.Length - br.BaseStream.Position) / 4 ' 4-byte short
Dim chartOffset As Int16 = 0
'Define chart properties
MyChart.Aspect.View3D = False
MyChart.Legend.LegendStyle = Steema.TeeChart.LegendStyles.Series
MyChart.Legend.Alignment = Steema.TeeChart.LegendAlignments.Right
MyChart.Width = 2000 'chartWidth / 10
MyChart.Height = numCharts * 150 'each axis is 150 pixel height
MyChart.Header.Text = ""
MyChart.Axes.Left.EndPosition = 0
MyChart.Panel.MarginTop = 0
MyChart.Panel.MarginBottom = 0
MyChart.Axes.Left.Labels.CustomSize = 60
MyChart.Axes.Left.MinimumOffset = 10
MyChart.Axes.Left.MaximumOffset = 10
MyChart.Axes.Bottom.MinimumOffset = 10
MyChart.Axes.Bottom.MaximumOffset = 10
MyChart.Aspect.SmoothingMode = System.Drawing.Drawing2D.SmoothingMode.HighQuality
MyChart.Aspect.TextRenderingHint = System.Drawing.Text.TextRenderingHint.ClearTypeGridFit
Panel2.Controls.Add(MyChart)
Dim myStartPos As Double = 0.5
Dim myChartSize As Double = (100 / numCharts) - 1
axis1 = New Steema.TeeChart.Axis(MyChart.Chart) ' define an axis for this series
MyChart.Axes.Custom.Add(axis1)
axis1.Horizontal = False
axis1.OtherSide = False
axis1.Labels.CustomSize = 100
axis1.Title.Angle = 90
axis1.Title.Caption = chartLegends(i)
axis1.StartPosition = myStartPos
axis1.EndPosition = (myStartPos + myChartSize) Mod 100
myStartPos += (myChartSize + 0.4)
cursorTool1 = New Steema.TeeChart.Tools.CursorTool()
cursorTool1.FollowMouse = True
cursorTool1.Active = True
cursorTool1.Pen.Style = System.Drawing.Drawing2D.DashStyle.Dash
cursorTool1.Style = Steema.TeeChart.Tools.CursorToolStyles.Vertical
cursorTool1.Pen.Color = Color.DarkGreen
MyChart.Tools.Add(cursorTool1)
AddHandler cursorTool1.Change, AddressOf cursorTool1_Change
myFastLine(i).CustomVertAxis = axis1
cursorTool1.Series = myFastLine(i)
myFastLine(i).Title = chartLegends(i)
MyChart.Series.Add(myFastLine(i))
Next
end if
Hi asupriya,
Could you please try running code below and let us know how it goes at your end and also let us know the environment you are using?
Also, if you uncomment the MyCursor.FastCursor = True line the application is even faster as no chart redraw is necessary.
Using code below, building the applicaiton in release mode and running application's .exe it takes between 55 and 90 milliseconds updating all cursors using latest TeeChart for .NET v3 release available in an Intel Core 2 Quad 6600 machine with 4 GB RAM and a nVidia GeForce 8500 GT graphic card.I already assign the cursortool in the way you suggested. However, the problem is during the cursorTool1.Change event handling. My code is as follows. It takes about 20-30 sec to change surser position on all the 15 charts. Please suggest a better alternative.
Imports System.IO
Public Class Form1
InitializeChart()
Private WithEvents MyCursor As New Steema.TeeChart.Tools.CursorTool
Private WithEvents TChart1 As Steema.TeeChart.TChart
Private WithEvents CursorTool1 As New Steema.TeeChart.Tools.CursorTool
Private Label1 As Label
Private panels() As Panel = New Panel(15) {}
Private stopWatch As System.Diagnostics.Stopwatch
Dim w As Integer = 150
Dim h As Integer = 100
panels(i).Location = New Point(w * (i Mod 5), h * (i Mod 3))
panels(i).Width = w
panels(i).Height = h
MyChart.Series.Add(New Steema.TeeChart.Styles.FastLine())
MyChart(0).Color = Color.DarkBlue
MyCursor = New Steema.TeeChart.Tools.CursorTool(MyChart.Chart)
'MyCursor.FastCursor = True
MyCursor.XValue = 5
MyCursor.YValue = 5
MyCursor.XValue = 5
Next
TChart1 = New Steema.TeeChart.TChart()
Me.Controls.Add(TChart1)
TChart1.Location = New Point(0, h * 3)
Dim FastLine1 As New Steema.TeeChart.Styles.FastLine(TChart1.Chart)
FastLine1.Color = Color.Red
FastLine1.LinePen.Width = 3
FastLine1.FillSampleValues()
CursorTool1 = New Steema.TeeChart.Tools.CursorTool(TChart1.Chart)
CursorTool1.Style = Steema.TeeChart.Tools.CursorToolStyles.Vertical
CursorTool1.FollowMouse = True
AddHandler CursorTool1.Change, AddressOf cursorTool1_Change
Label1 = New Label
Me.Controls.Add(Label1)
Label1.Location = New Point(TChart1.Width + 10, TChart1.Location.Y + 100)
Label1.AutoSize = True
Me.Width = w * 5
Me.Height = h * 3 + TChart1.Height
stopWatch = New System.Diagnostics.Stopwatch()
AddHandler CType(panels(0).Controls.Item(0), Steema.TeeChart.TChart).BeforeDraw, AddressOf MyChart_BeforeDraw
AddHandler CType(panels(panels.Length - 1).Controls.Item(0), Steema.TeeChart.TChart).AfterDraw, AddressOf MyChart_AfterDraw
Dim i As Int32
For i = 0 To panels.Length - 1
CType(CType(panels(i).Controls.Item(0), Steema.TeeChart.TChart).Tools.Item(0), Steema.TeeChart.Tools.CursorTool).XValue = e.XValue
Next
stopWatch.Stop()
Dim elapsedTime As TimeSpan = stopWatch.Elapsed
Label1.Text = "Elapsed time: " + elapsedTime.TotalMilliseconds.ToString() + " ms"
Private Sub MyChart_BeforeDraw(ByVal sender As System.Object, ByVal g As Steema.TeeChart.Drawing.Graphics3D)
stopWatch.Reset()
stopWatch.Start()
End Class
Could you please arrange an example similar to the one above so that we can reproduce the issue here?1. I am experimenting with the same data used in the dynamic generation of each chart for each of the data series with single chart and multiple custom left axis option. Each of the series has its own custom left axis on a single chart object. The intention is that this method would be much more faster than the previous method where you generate as many charts as the distinct series. But, to my surprise, this method of single chart with multiple custom left charts is much slower than the multiple charts method (keeping the rest all the same - series, data, etc.). Can you please comment on it? Below is the snippet of code.
Try this:2. Other question is: How can i change the thickness of the myfastline(i) in the above code?
myFastLine(i).LinePen.Width = 3
Thanks. Your machine is very high end. We are developing for a "typical" machine configuration with around 512 MB RAM, >2GHz processor, and "average" video card. I will try and let you know the time for the code you posted.
The delay (in custom left axis scenario) is not really in chart generation, but in the display/paint. When i debugged earlier (without stopwatch), all the chart instantiation and series population gets done in "reasonable" amount of time, but the final display (probably draw/paint call) takes long time to show up. I will get you the actual numbers probably today or so. It could be my graphics card (Intel 82852/82855 GM/GME Graphics card with 64 MB video RAM) that is the root cause of these issues.
Reg. the cursortool1.change event, i continue to have same problem of delay in cursor updates. With fastcusor set to true, the charts are marked with random lines in the direction of mouse movement (probably graphics card issue). I will create a test project in a day or so and upload it for your reference.
Here are some more questions i have:
1. I defined this cursortool1.change event and get the e.xvalue and e.yvalue posted in the status bar. Now, i also activated Mark-tip tool for each of the series. There is a slight difference of values for the same cursor position in the cursortool1.event's e.xvalue and the Mark-tip tool's display with Steema.TeeChart.Styles.MarksStyles.XY style. The difference is in the digits after the decimal. e.yvalue matches with the mark-tip value. Also sometimes, the comma between the X and Y values doesn't showup. I am wondering which is more accurate and why such a variation.
2. Just as synchronized cursors, i like to optionally sync the zoom and scroll activities as well across different charts we dynamically create. I defined the handler as follows. But, i am not sure how i can access the user created zoom rectangle and pass it to other chart objects. Please suggest how i should proceed.
3. My charts are each 150 pixels in height. When printing one chart, i like to magnify it to occupy full page in landscape mode. I tried to set the margins and played with the other settings, but could not figureout how to magnify the chart to "fit the page" so that it will be legible. I have a long chart (chart.width=2000) and like to print it into several pages with legible chart, labels, and series data. Please suggest.
4. Now, i also want to print about three of the above generated charts into one page. As you can see, each chart is generated separately, but while printing, i like to club them so that user can choose which three charts go into a common print job on a single sheet (with possible magnification as needed in point 3). Please suggest how i should proceed.
Hi asupriya,
Regarding the comma between X and Y issue in MarksTip, by default it's not displayed. You can customize mark text using GetMarkText event or MarksTip's GetText event.
http://www.teechart.net/support/viewtopic.php?t=4305
You may also be interessed in those threads:
http://www.teechart.net/support/viewtopic.php?t=5490
http://www.teechart.net/support/viewtopic.php?t=3424
http://www.teechart.net/support/viewtopic.php?t=5756
http://www.teechart.net/support/viewtopic.php?t=1883
Hope this helps!
Using powerful machines we make our work faster and I guess we are more productive that wayThanks. Your machine is very high end. We are developing for a "typical" machine configuration with around 512 MB RAM, >2GHz processor, and "average" video card. I will try and let you know the time for the code you posted.
If you can it would be good that you made the tests in different machine configurations so that you can compare results.The delay (in custom left axis scenario) is not really in chart generation, but in the display/paint. When i debugged earlier (without stopwatch), all the chart instantiation and series population gets done in "reasonable" amount of time, but the final display (probably draw/paint call) takes long time to show up. I will get you the actual numbers probably today or so. It could be my graphics card (Intel 82852/82855 GM/GME Graphics card with 64 MB video RAM) that is the root cause of these issues.
I can't reproduce this here.Reg. the cursortool1.change event, i continue to have same problem of delay in cursor updates. With fastcusor set to true, the charts are marked with random lines in the direction of mouse movement (probably graphics card issue). I will create a test project in a day or so and upload it for your reference.
MarksTip tool displays the exact value of each point in the series. While CursorTool's values and they may not be in the very same point as series values.1. I defined this cursortool1.change event and get the e.xvalue and e.yvalue posted in the status bar. Now, i also activated Mark-tip tool for each of the series. There is a slight difference of values for the same cursor position in the cursortool1.event's e.xvalue and the Mark-tip tool's display with Steema.TeeChart.Styles.MarksStyles.XY style. The difference is in the digits after the decimal. e.yvalue matches with the mark-tip value. Also sometimes, the comma between the X and Y values doesn't showup. I am wondering which is more accurate and why such a variation.
You should use Zoomed, UndoneZoom and Scroll events to retrieve zoomed/scrolled chart axes min. and max. values and set them to the other charts using axis SetMinMax method.2. Just as synchronized cursors, i like to optionally sync the zoom and scroll activities as well across different charts we dynamically create. I defined the handler as follows. But, i am not sure how i can access the user created zoom rectangle and pass it to other chart objects. Please suggest how i should proceed.
You can do as shown here:3. My charts are each 150 pixels in height. When printing one chart, i like to magnify it to occupy full page in landscape mode. I tried to set the margins and played with the other settings, but could not figureout how to magnify the chart to "fit the page" so that it will be legible. I have a long chart (chart.width=2000) and like to print it into several pages with legible chart, labels, and series data. Please suggest.
What I told in previous answer should help you on setting charts dimension. As far as printing mulitple charts you can have a look here:4. Now, i also want to print about three of the above generated charts into one page. As you can see, each chart is generated separately, but while printing, i like to club them so that user can choose which three charts go into a common print job on a single sheet (with possible magnification as needed in point 3). Please suggest how i should proceed.
Hope this helps!
1.
Printing with large plot and paper size works like charm. Thanks. I need to spend some time to do the multi-chart part as well.
2. I need similar functionality as shown in the .Net examples (You need to search the Example Demo with keyword "Enable Functions" and you get only one hit) that enables users to click on the series to change its color. Along with the color, i need to be able to change all pen properties. I need such a functionality when user double-clicks on the legend of a fastline series. I looked in the demo code for this demo, but couldn't really follow how i can capture a click event for a dynamically generated series and its legend.
Can you please show some sample code with two dynamically generated charts sync'ing for zoom and scroll? I don't know how to get the user defined rectangle for the zoom action.You should use Zoomed, UndoneZoom and Scroll events to retrieve zoomed/scrolled chart axes min. and max. values and set them to the other charts using axis SetMinMax method.
Hi asupriya,
I have applied that to dynamic charts in the example below.
You should do something as what I suggested here.Can you please show some sample code with two dynamically generated charts sync'ing for zoom and scroll? I don't know how to get the user defined rectangle for the zoom action.
I'm glad to hear that.Printing with large plot and paper size works like charm. Thanks. I need to spend some time to do the multi-chart part as well.
Ok, I've also added this feature to the example below using PenEditor and ClickLegend event.2. I need similar functionality as shown in the .Net examples (You need to search the Example Demo with keyword "Enable Functions" and you get only one hit) that enables users to click on the series to change its color. Along with the color, i need to be able to change all pen properties. I need such a functionality when user double-clicks on the legend of a fastline series. I looked in the demo code for this demo, but couldn't really follow how i can capture a click event for a dynamically generated series and its legend.
Imports System.IO
Public Class Form1
InitializeChart()
panels(i).Width = w
'MyChart.Legend.Visible = False
AddHandler MyChart.Zoomed, AddressOf tChart1_Zoomed
AddHandler MyChart.UndoneZoom, AddressOf tChart1_UndoneZoom
AddHandler MyChart.Scroll, AddressOf tChart1_Scroll
AddHandler MyChart.ClickLegend, AddressOf tChart1_ClickLegend
MyCursor.XValue = 5
MyCursor.YValue = 5
MyCursor.XValue = 5
Next
Label1 = New Label
Me.Width = w * 5
Dim i As Int32
Next
stopWatch.Stop()
stopWatch.Reset()
stopWatch.Start()
Private Sub tChart1_Zoomed(ByVal sender As Object, ByVal e As System.EventArgs)
UpdateAxes(sender)
Private Sub tChart1_Scroll(ByVal sender As Object, ByVal e As System.EventArgs)
UpdateAxes(sender)
Private Sub tChart1_UndoneZoom(ByVal sender As Object, ByVal e As System.EventArgs)
UpdateAxes(sender)
Private Sub UpdateAxes(ByVal sender As Object)
Dim OrgChart As Steema.TeeChart.TChart = CType(sender, Steema.TeeChart.TChart)
Dim DestChart As Steema.TeeChart.TChart
OrgChart.Refresh()
DestChart = CType(panels(i).Controls.Item(0), Steema.TeeChart.TChart)
If (Not OrgChart.Equals(DestChart)) Then
DestChart.Axes.Bottom.SetMinMax(OrgChart.Axes.Bottom.Minimum, OrgChart.Axes.Bottom.Maximum)
DestChart.Axes.Left.SetMinMax(OrgChart.Axes.Left.Minimum, OrgChart.Axes.Left.Maximum)
End If
Next
Private Sub tChart1_ClickLegend(ByVal sender As Object, ByVal e As MouseEventArgs)
Dim MyChart As Steema.TeeChart.Chart = CType(sender, Steema.TeeChart.Chart)
Dim Index As Integer = MyChart.Legend.Clicked(e.X, e.Y)
Dim Series As Steema.TeeChart.Styles.FastLine
If ((Index <> -1) And (MyChart.Series.Count >= Index)) Then
Series = CType(MyChart.Series(Index), Steema.TeeChart.Styles.FastLine)
Steema.TeeChart.Editors.PenEditor.Edit(Series.LinePen)
End If
End Class
