ATS
Post
by ATS » Tue Jul 20, 2004 8:46 pm
I tried to use
this.lotChart.YValues.DataMember=datasource.Columns["LotTypeID"].ToString();
this.lotChart.LabelMember=datasource.Columns["LotName"].ToString();
this.lotChart.StartValues.DataMember=datasource.Columns["StartTime"].ToString();
this.lotChart.EndValues.DataMember=datasource.Columns["StopTime"].ToString();
to generate a Gantt Series. But it seems the X-Asix value is not correct. It only shows from the earliest StopTime. And bars have same Y value didn't show on the same high level.
What's the problem?
May I bind the datatable to a Gantt Series?
Post
by Marc » Mon Jul 26, 2004 3:54 pm
Thanks for reporting that. It is a bug and has been resolved for the next maintenance release.
Until that is available an interim measure would be to step through the dataset and use the corrsponding Gantt Add method to take the record data.
