Large numbers (Invalid floating point operation)
JES
Post by JES » Sun Feb 15, 2009 1:19 pm
In version 8.04 when adding large number(s) I get "Invalid floating point operation" -error when chart refresh (draws itself).
   DBChart1.Series[0].addxy(0,9.58737850189209);
   DBChart1.Series[0].addxy(1,3.40282346638529E+38);
   DBChart1.Series[0].addxy(2,10.2478742599487);
Is it a bug or is there another way to add large numbers?
Post by Yeray » Mon Feb 16, 2009 10:32 am
Hi JES,
Yes, having a distance so big in values it causes an error. But I've solved the problem and it will be ready for next maintenance release.
I've seen that you are a source code customer so, if you want, you could implement the change to fix it before than the next maintenance release will be available. You simply should edit your TeEngine.pas and change one line at the beginning of the CalcIncrement function. You should have:
Function TChartAxis.CalcIncrement:Double;
var tmp    : Integer;
    tmpMin : Double;
    tmpMax : Double;
    tmpMid : Double;
    tmp2   : Integer;
  if RoundFirstLabel and (Increment<>0) then
    tmpMin:=Increment*Round(IMinimum);
    tmpMax:=Increment*Trunc(IMaximum);
  end
You should change it for:
var tmp    : Integer;
    tmpMin : Double;
    tmpMax : Double;
    tmpMid : Double;
    tmp2   : Integer;
    tmpMax:=Increment*Int(IMaximum);
  end
JES
Post by JES » Mon Feb 16, 2009 11:01 am
ok!
JES
