Working with the Marks.Item list
qcrnd
Post by qcrnd » Sun May 31, 2009 5:49 am
I have a bar chart and for each bar series I tried to work with the Marks.Item list , but I dont see the marks I defined in the item list.
How exactly am I supposed to work with this .
Post by Sandra » Mon Jun 01, 2009 8:47 am
Hello gcrnd,
Please, you could explain exactly that you want do with marks in your application, so we can suggest a solution for your problem.
qcrnd
Post by qcrnd » Tue Jun 02, 2009 9:18 am
I have a stacked bar chart and I want a mark on top of each stacked bar with the total . Until now I have used the Mark of the top most series and it worked ok ( bar.Mark.Visible = true) however because of problem that you have with 0 values, I was suggested by Yeray to use a workaround which involved working with the Marks.Items of each series. but I cant seem to see the Marks that are in the Items list . I think I am not working properly with the Marks.Items list and want to know what I should do.
Post by Yeray » Tue Jun 02, 2009 9:46 am
Hi qcrnd,
I'm still able to understand you. Could you change the following code to reproduce the problem?
            //create ans populate 4 bar series
            for (int i = 0; i < 4; i++)
                new Bar(tChart1.Chart);
                tChart1.Series[i].FillSampleValues(5);
                ((Bar)tChart1.Series[i]).MultiBar = MultiBars.Stacked;
            //set some of the series values as 0
            tChart1.Series[1].YValues[2] = 0;
            tChart1.Series[2].YValues[2] = 0;
            tChart1.Series[3].YValues[4] = 0;
            tChart1.Series[0].YValues[3] = 0;
            //process of setting the 0 values as null to aviod drawing them
            for (int i = 0; i < tChart1.Series.Count; i++)
                for (int j = 0; j < tChart1.Series[i].Count; j++)
                    if (tChart1.Series[i].YValues[j] == 0)
                        tChart1.Series[i].SetNull(j);
            //process for show only the last mark on each series
            for (int ValueIndex = 0; ValueIndex < tChart1.Series[0].Count; ValueIndex++)
                int SeriesIndex = tChart1.Series.Count - 1;
                while ((SeriesIndex > 0) && (tChart1.Series[SeriesIndex].IsNull(ValueIndex)))
                    SeriesIndex--;
                for (int k = 0; k < tChart1.Series.Count; k++)
                    tChart1.Series[k].Marks.Items[ValueIndex].Visible = k == SeriesIndex;
qcrnd
Post by qcrnd » Wed Jun 03, 2009 1:33 pm
Hi Yeray
Thanks. The only problem is ... HOW can I set the marks Items text to something else.
tChart1.Series[k].Marks.Items[ValueIndex].Text = MyString doesnt have any effect.
Post by Yeray » Wed Jun 03, 2009 2:22 pm
Hi qcrnd,
Oh, now I think I understood you. Excuse me.
To change your series marks text you have two options:
- Set your desired text as your series points labels. You could do it when you add the points with the Add() method or you could loop your series and their values to change its labels:
      tChart1.Series[i].Labels[j] = "your text";
- Use OnGetMarkText: You could assign the same method to all the series OnGetMarkText events:
    tChart1.Series[i].GetSeriesMark += new Series.GetSeriesMarkEventHandler(Form1_GetSeriesMark);
And then use the event call to change the text to show as you wish:
void Form1_GetSeriesMark(Series series, GetSeriesMarkEventArgs e)
    e.MarkText = "Label number " + (e.ValueIndex+1).ToString();
qcrnd
Post by qcrnd » Thu Jun 04, 2009 8:22 am
I Yeray
Thanks. I tried the Labels , and it seems OK Except for one problem which I also saw before in other charts.
Sometimes the Marks , and the Labels on the x Axis get mixed up. for example a label on the x Axis can suddenly change after resize to the same string as the mark , and visa versa.
Is this a defect that you know about.?
Post by Yeray » Thu Jun 04, 2009 11:58 am
Hi qcrnd,
Could you explain us how could we reproduce it here or could you send us a simple example project we can run "as-is" to reproduce the problem here?
qcrnd
Post by qcrnd » Thu Jun 04, 2009 12:24 pm
Hi Yeray
Its not easy to reproduce, it only happens sometimes in our application but I cant send you something so big. I will maybe try later on to build something small and see if it happens.
