Automatic Axis
Luke
Automatic Axis
Post by Luke » Thu Jun 04, 2009 9:32 am
Is there any way to reset these?
If I use the same chart control to display mulptile charts, some have automatic axis some dont. The plot never comes back the same even when switching the automatic back to true?
Chart.Axes.Bottom.AutomaticMaximum = false;
tChart.Axes.Bottom.AutomaticMinimum = false;
tChart.Axes.Bottom.SetMinMax(x,y)
then reset using
tChart.Axes.Bottom.Automatic = true;
tChart.Axes.Bottom.AutomaticMaximum = true;
tChart.Axes.Bottom.AutomaticMinimum = true;
next time I use the chart the automatic max min is not the same when I used it before disabling automatic!!!!!!!!!
Post by Yeray » Thu Jun 04, 2009 12:15 pm
Hi Luke,
Minimum and maximum properties are overwritten once you set AutomaticMinimum and AutomaticMaximum as true, is that what you mean?
If I understood you well, I think this is correct because when you set the axis as automatic, they recalculate their min and max values.
If you want to remember the previous values, you should use another variable.
Luke
Post by Luke » Thu Jun 04, 2009 12:19 pm
I would use the same tChart control and for 1 chart (a line chart with dates on bottom axis) I have auto axis.
I then use same chart to display a bar chart. With manual Maximum on the bottom axis. (I have to do this as automaximum cuts the bars to short if they are bordered) The maximum value doesnt get it border at the end.
I then switch back to Chart 1 with the exact data. However the auto max is now different to the First auto max. Even though I have toggle the maximums back to automatic.
Post by Yeray » Thu Jun 04, 2009 1:25 pm
Hi Luke,
Please, could you send us a simple example project we can run "as-is" to reproduce the problem here? I'm not sure to understand the exact process I should follow to reproduce it. Should I delete the initial line series and then add a bar series or should I "change" the initial line series to a bar series?
