Pujol1986
Post
by Pujol1986 » Thu Jun 04, 2009 2:15 pm
Hello, I'm using this code to change and show the marks value of my polygons
Private Sub Map1_GetSeriesMark(ByVal series As Steema.TeeChart.Styles.Series, ByVal e As Steema.TeeChart.Styles.GetSeriesMarkEventArgs) Handles Map1.GetSeriesMark
e.MarkText = "Prueba"
MessageBox.Show(e.MarkText)
Private Sub CheckBox2_CheckedChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles CheckBox2.CheckedChanged
If CheckBox2.Checked = True Then
Map1.Marks.Visible = False
Else
Map1.Marks.Visible = True
End If
The messagebox is never shown. I'm doing something wrong?
I have an aplication with gantt series and it works fine.
Post
by Yeray » Thu Jun 04, 2009 3:06 pm
Hi Pujol1986,
It seems that he marks are broken for the map series since v3.5.3274.30662. We'll investigate the changes made on it (TF02014217).
Pujol1986
Post
by Pujol1986 » Wed Jun 10, 2009 2:59 pm
I've the teechart v3 for visual studio 2008
I see that the last maintenance release don't have this error fixed. And I've read that this would be the last maintenance release...
what I should do to have this problem solved?
I need to see the marks on my map series.
Post
by Narcís » Wed Jun 10, 2009 3:02 pm
Hi Pujol1986,
Latest TeeChart for .NET v3 maintenance release available won't be the last we publish. Even TeeChart for .NET 2009 is already available we will still continue publishing updates for v3 for some time.
Pujol1986
Post
by Pujol1986 » Wed Jun 10, 2009 3:05 pm
okay, thanks Narcís, I'll check the release notes occasionally to see if this issue is solved.
Post
by Narcís » Thu Jun 11, 2009 7:05 am
Hi Pujol1986,
You're welcome. You may also be interested in subscribint to our
RSS news feed for automatic announcements.
