legend with checkbox style
Neelam
Re: legend with checkbox style
Post by Neelam » Wed Jun 17, 2009 8:05 am
thanx.. where exactly i need to paste this code ( i mean in which event/procedure)...it will be great if you can send the whole code taht works for u..
Post by Yeray » Wed Jun 17, 2009 8:11 am
Hi shikha,
I've simply modified the code you've sent to us by adding the mentioned code at the end of your InitializeChart method. Here is the whole code (cleaned of commented code):
Public Class Form1
    Public Sub New()
        InitializeComponent()
        InitializeChart()
    Private Sub InitializeChart()
        TChart1.Aspect.View3D = False
        Dim barSeriesBase As Steema.TeeChart.Styles.Bar
        barSeriesBase = New Steema.TeeChart.Styles.Bar
        barSeriesBase.Add(123, "A")
        barSeriesBase.Add(456, "dr")
        barSeriesBase.Add(321, "rea")
        TChart1.Series.Add(barSeriesBase)
        barSeriesBase.MultiBar = Steema.TeeChart.Styles.MultiBars.Stacked
        TChart1.Series.Add(New Steema.TeeChart.Styles.Bar())
        TChart1.Series(1).Clear()
        TChart1.Series(1).Add(221, "cd")
        TChart1.Series(1).Add(456, "bg")
        TChart1.Series(1).Add(321, "rea")
        TChart1.Series(2).Clear()
        TChart1.Series(2).Add(100, "csd")
        TChart1.Series(2).Add(456, "bsg")
        TChart1.Series(2).Add(321, "resa")
        TChart1.Legend.CheckBoxes = True
        TChart1.Legend.LegendStyle = Steema.TeeChart.LegendStyles.Series
        ' force a first repaint to set minimum and maximum for the axes
        TChart1.Draw()
        ' now you can force the axis not to move
        TChart1.Axes.Left.Automatic = False
        TChart1.Axes.Bottom.Automatic = False
        ' you could add a dummy series (series without data) to force axis to be always drawn
        TChart1.Series(TChart1.Series.Count - 1).ShowInLegend = False
        ' you should finally clear the bottom axis labels and draw the ones you wish
        TChart1.Axes.Bottom.Labels.Items.Clear()
        TChart1.Axes.Bottom.Labels.Items.Add(0, "label 1")
        TChart1.Axes.Bottom.Labels.Items.Add(1, "label 2")
        TChart1.Axes.Bottom.Labels.Items.Add(2, "label 3")
End Class
Neelam
Post by Neelam » Wed Jun 17, 2009 9:52 am
EXCELLENT!!! this worked!! THANKS SO MUCH .......................... :D
