Iam using BarJoin,
I want to keep the numbers on each bar as in the attached picture.
Also, I want to control the information title as in the red cycle. without effectig the number yellow box on the top of each bar.
Can you help me plz?
Thanks!
How To change or Remove the info box
- question.jpg (15.57 KiB) Viewed 4309 times
Re: How To change or Remove the info box
Hello Rabbit,
I make a simple example. You can use a similar code in your application for control text in the legend.
I hope that will helps.
Steema.TeeChart.Styles.BarJoin barjoin;
barjoin = new Steema.TeeChart.Styles.BarJoin(tChart1.Chart);
barjoin.Add(100, 25, "value1");
barjoin.Add(125, 35, "value2");
barjoin.Marks.Style = Steema.TeeChart.Styles.MarksStyles.Value;
