Bug in Zoom with TPointSeries
beetle
Post by beetle » Thu Jul 02, 2009 5:26 pm
I have this bug since forever but now I can reproduce it for you. I have this issue almost every time I zoom all kind of charts I have with one TPointSeries in them (no more series), and It turns out that if I add points with AddXY instead of using DynamicArrays, this issue is not present. The bad thing is that AddXY is wayyyy slower than using DynamicArray, so not suitable for my charts (a lot of thousands of points). What is the internal difference between those two options to add points to series???
In the uploaded project, data used is loaded from the file chart.tee; there's one button for loading data using DynamicArray and another using AddXY. You may check the issue doing zoom in almost every zone of the chart, but I usually do it over the four points around coordinates (-2.3, 0.6).
I'm using TeeChart Pro v7.12 Win32 and CodeGear™ C++Builder® 2007.
Thanks!
ZoomPointSeriesIssue.rar
(346.34 KiB) Downloaded 1252 times
Re: Bug in Zoom with TPointSeries
Post by Yeray » Fri Jul 03, 2009 10:47 am
Hi beetle,
Have you seen the Real-time Charting article? Maybe you can still improve your chart optimization a little bit with some of the tips explained there.
The AddXY method makes some internal verifications and that's why it could result in a little lag. I think you could improve the AddXY way disabling AutoRepaint before a the AddXY iteration and enable it after the addition.
Finally, I've been testing your application, and the problem seems to be the XValues Order. If you set the following, using DynamicArrays seems to zoom fine:
series->XValues->Order = loNone;
beetle
Post by beetle » Fri Jul 03, 2009 4:10 pm
Hi Yeray!
Yes, I follow the tips of your real-time charting article since several years ago and they are a great improvement. Anyway, there's a huge speed difference between AddXY and DynamicArray in spite of disabling AutoRepaint (or the Series->BeginUpdate thing). The good news is that the zoom bug we are talking about is fixed with your workaround, altough zoom speed has decreased way down :( . Zoom speed is the same for an area with 1 point than for an area with all points. If you think of another way to increase zoom speed again, it would be appreciated :)
Thanx!
Post by Yeray » Mon Jul 06, 2009 8:26 am
Hi beetle,
With your application, I can't see any difference in Zoom speed. Could you please send us another simple example project we can run as-is here to reproduce this here?
beetle
Post by beetle » Mon Jul 06, 2009 9:06 am
yes, I can see speed differences in that application but maybe your computer is quite better than mine, so you have to use more points. You can change the line:
	LoadChartFromFile((TCustomChart*)Chart1, "chart.tee");
for this code:
	TPointSeries* series = new TPointSeries(Chart1);
	Chart1->AddSeries(series);
	series->FillSampleValues(300000);
You can use another number of samples depending on the speed of your computer but I wouldn't click on the "AddXY" button because it takes like forever to add all the points :lol: Besides, the zoom issue just appears using DynamicArray to load points.
I hope you can see it now.
Thanks!
Post by Yeray » Mon Jul 06, 2009 10:07 am
Hi beetle,
Yes, the problem is that with this amount of points, each repaint takes a while. With FastLine series there is the DrawAllPoints property probably would help you to increase the draw speed. But with a PointSeries I'm afraid that I only can think on, if the lag is important maybe you should consider removing your series data, create a temporal array that contains only the values that will be shown in the zoomed area, and reassign the values arrays.
beetle
Post by beetle » Mon Jul 06, 2009 10:59 am
thanks anyway, the important thing is there's no bug anymore, in spite of losing speed while zooming. I'll get a more powerful PC so far, but you should consider to improve this kind of speed issues in series with Pointer (TLineSeries, TPointSeries). Besides, I suggest another way to manage pointer styles for all points, different from the OnGetPointerStyle event (now issues one function call per point), and maybe add the same behaviour as in DrawAllPoints=false in TFastLineSeries. Those just are some hints coming off my mind :roll:
Post by Yeray » Mon Jul 06, 2009 11:23 am
Hi beetle,
Of course, we will try to improve Point and Line series with tips like those you suggested but, as you understand, drawing a huge amount of points will always be delicate.
beetle
Post by beetle » Wed Jul 08, 2009 10:31 am
I've been working in speed improvement with TPointerSeries and now I can work with several million points 10-15 times faster. To do so, I've implemented my own class derived from TPointerSeries and reimplemented 2 functions only, but the most important thing I did is preprocessing to choose which points have to be drawn, and issued every Pointer->DrawPointer call in the OnAfterDraw handler. I believe this preprocessing thing is something similar to your "TFastLineSeries::DrawAllValues=false" behaviour.
Besides, with this new implementation, there's no need to put "series->XValues->Order = loNone;" to avoid the zoom issue of this topic and thus Zoom is really fast again.
I did the same with TLineSeries and I've doubled speed whether Pointer is visible but I could get more speed if I do the same for the line points, so I need to know where in the source code line drawing is done for every series points.
Post by Yeray » Wed Jul 08, 2009 1:29 pm
Hi beetle,
1. I'm happy to see that you are achieving satisfactory results with TeeChart now! Even if you had to modify its source a little bit... ;)
2. Yes, to see how Lines are drawn take a look at the method:
procedure TCustomSeries.DrawValue(ValueIndex:Integer);
You should find it at Series.pas file, TCustomSeries class.
beetle
Post by beetle » Thu Jul 09, 2009 10:43 am
I got this too. You just may derive from TLineSeries and override the DrawValue method like this:
void __fastcall TISALineSeries::DrawValue(int ValueIndex)
	x=GetHorizAxis->CalcXPosValue(XValues->Value[ValueIndex]); // x coordinate for ValueIndex
	y=GetVertAxis->CalcYPosValue(YValues->Value[ValueIndex]); // y coordinate for ValueIndex
	if(x == oldx) // Skip "redundant" points
		if(abs(y - oldy) < toleranceY) // I take a 5% tolerance of its Vertical Axis Height, that is (GetVertAxis->IEndPos - GetVertAxis->IStartPos)*0.05
			return;
	oldx = x;
	oldy = y;
	TLineSeries::DrawValue(ValueIndex);
where "toleranceY" is the y gap threshold for which several points of same x coordinate (in pixels) are drawn. TFastLineSeries with the property "DrawAllPoints=false" doesn't draw more than one point with the same x coordinate (in pixels), regardless of y coordinate, (that is, toleranceY tends to infinite), so you could be missing important series peeks.
Post by Yeray » Thu Jul 09, 2009 11:51 am
Hi beetle,
In v9 it will be possible to combine DrawAllPoints:=false with a new property DrawAllPointsStyle:=daMinMax that should show those peeks for FastLineSeries.
  series1.DrawAllPoints := false;
  series1.DrawAllPointsStyle := daMinMax;
