Legend Title
UserLS
Legend Title
Post by UserLS » Mon Nov 02, 2009 7:59 pm
My legend is showing series names (which are not very long). I assigned a title to it (which is longer than any of my series names). If I place the legend on the left or right side of the graph, it is displayed fine. But top and bottom options are broken (you can see it, if you'll set borders around legend itself and the title).
Re: Legend Title
Post by Yeray » Tue Nov 03, 2009 12:22 pm
Hi UserLS,
I'm trying to reproduce it but I'm afraid I can't. I'm trying to do it with the following code, could you try it?
            for (int i = 0; i < 5; i++)
                new Steema.TeeChart.Styles.Line(tChart1.Chart);
                tChart1[i].FillSampleValues(25);
            tChart1[0].Title = "my long series title name";
            tChart1.Legend.Alignment = Steema.TeeChart.LegendAlignments.Top;
            tChart1.Legend.Pen.Width = 2;
            tChart1.Header.Transparent = false;
            tChart1.Header.Pen.Width = 2;
Could you please modify the code to make the problem reproducible? Or could you please explain the exact steps I should follow to reproduce it here?
UserLS
Re: Legend Title
Post by UserLS » Tue Nov 03, 2009 1:40 pm
Hi, Yeray!
I did not write any code. I just set up a graph using your editor and get the following result:
Re: Legend Title
Post by Yeray » Tue Nov 03, 2009 4:08 pm
Hi UserLS,
Sometimes an image is more clear than a thousand words ;)
I understood now what you mean, I could reproduce it with the following code and I've added it to the wish list to be fixed in future releases (TF02014531).
            new Steema.TeeChart.Styles.Area(tChart1.Chart);
            tChart1[0].FillSampleValues(25);
            tChart1.Legend.LegendStyle=Steema.TeeChart.LegendStyles.Series;
            tChart1.Legend.Title.Visible = true;
            tChart1.Legend.Title.Text = "My Legend Title";
            tChart1.Legend.Alignment = Steema.TeeChart.LegendAlignments.Bottom;
Note that we usually ask our customers to send us examples or code snippets because the explanations about what is done at design time can easily end in confusion.
