Again printer setting problem in VB.NET
M.Takeda
Post by M.Takeda » Wed Sep 22, 2004 11:03 am
Thank you for your prompt reply and help me again
to check my source code attached.
This is working well using default printer only.
Printer does not change as print dialog setting.
' Put Chart and Set Print Margine
Private Sub Form3_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
If Fmain.MenuItem5.Checked Then
' Analog Page
With Fmain
With .AxTChart1.Printer
.PrintProportional = False
.MarginLeft = 5
.MarginTop = 5
.MarginRight = 5
.MarginBottom = 5
End With
AxTeePreviewPanel1.Orientation = TeeChart.ETeePreviewPanelOrientation.ppoLandscape
RadioButton1.Checked = True
AxTeePreviewPanel1.AddChartLink(.AxTChart1.ChartLink)
End With
ElseIf Fmain.MenuItem6.Checked Then
' Digital Page
With Fmain
With .AxTChart2.Printer
.MarginLeft = 5
.MarginTop = 5
.MarginRight = 5
.MarginBottom = 5
End With
AxTeePreviewPanel1.AddChartLink(.AxTChart2.ChartLink)
End With
ElseIf Fmain.MenuItem7.Checked Then
' Both Page
With Fmain
.MarginLeft = 5
.MarginTop = 5
.MarginRight = 5
.MarginBottom = 50
End With
.MarginLeft = 5
.MarginTop = 50
.MarginRight = 5
.MarginBottom = 5
End With
AxTeePreviewPanel1.Orientation = TeeChart.ETeePreviewPanelOrientation.ppoPortrait
RadioButton2.Checked = True
End With
End If
'Start Pring after execute printdialog
Private Sub Button3_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button3.Click
Dim result As DialogResult
PrintDialog1.PrinterSettings = New Printing.PrinterSettings
result = PrintDialog1.ShowDialog()
If result = DialogResult.OK Then
AxTeePreviewPanel1.PrintPage()
End If
'Cancel Button
Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
Me.Close()
I'm very sorry to attach long code.
Best Regards, Thank you very much in advance,
Post by Pep » Mon Sep 27, 2004 4:19 pm
Hi Takeda,
and it does not priint any page or just a empty page ?
