Pie in TChart disappears
qcrnd
Post by qcrnd » Wed Mar 03, 2010 1:30 pm
I have TChart embedded within a control displaying a pie. When the control becomes smaller the pie disappears, this wasn't a problem in Delphi what should i do
Jonathan
Re: Pie in TChart disappears
Post by Yeray » Thu Mar 04, 2010 9:05 am
Hi jonathan,
At what size are you seeing this? Or could you please tell us if I'm missing to set any important property to reproduce the problem here?
            Steema.TeeChart.Styles.Pie pie1 = new Steema.TeeChart.Styles.Pie(tChart1.Chart);
            pie1.Marks.Visible = false;
            pie1.FillSampleValues();
            tChart1.DoubleClick += new EventHandler(tChart1_DoubleClick);
        void tChart1_DoubleClick(object sender, EventArgs e)
            this.Width = 100;
            this.Height = 100;
qcrnd
Post by qcrnd » Sun Mar 07, 2010 8:21 am
I don't know what properties need to be set in order for pie chart to not disappear. That is what I need the help with. I checked our delphi code, there is not code handeling of the pie, so it most be something to do with the settings of properties. Please help me as this is very urgent.
Thank you jonathan
Post by Narcís » Mon Mar 08, 2010 8:25 am
Hi jonathan,
Could you please attach a simple example project we can run "as-is" to reproduce the problem here and let us know the exact TeeChart build you are using?
