Title Custom position questions
Perry
Post by Perry » Tue Dec 16, 2003 10:09 am
I have several questions about the Title custom position:
1. When I set Title.CustomPosition := True the grid will be aligned totally to the top. How can I prevent this so the grid stay where it was?
2. When I set Title.Alignment := taLeftJustify it will align totally to the right. I want to align it with the LeftAxis with the custom position. But because I don't know the position of the LeftAxis I can't calculate the Title.Left. How can I get the LeftAxis position so I can use it for the Title.Left?
Any help is very appreciated!
Thank you,
Perry van der Meeren
Post by Pep » Tue Dec 16, 2003 11:57 am
1) to prevent this you could change the MarginTop manually as in the following code.
2) You could get the left axis position in the OnBeforeDrawSeries event, the following code works fine :
Series1.FillSampleValues(10);
Chart1.Title.CustomPosition := true;
Chart1.MarginTop := 10;
procedure TForm1.Chart1BeforeDrawSeries(Sender: TObject);
Chart1.Title.Left:= chart1.Axes.Left.PosAxis;
chart1.Title.Top := 10;
Josep Lluis Jorge
http://support.steema.com
