SeriesBand Tool and Functions
Snarkle
Post by Snarkle » Thu Jul 15, 2010 7:40 am
Greetings,
Can the seriesBand tool be applied to functions ... for example the Bollinger Band ... It seems straight forward if you have 2 series .. but in the case of the Bollinger bands (Which will draw two lines on the Chart) is there a way to apply the SeriesBand tool to this ???
Also another quick question ... on Functions such as MACD and Bollinger Bands when I set the pen color and width only 1 of the series that is drawn has these values .. any other lines on the chart remain at defaults ... is there a way to to apply the pen colors and widths to ALL the drawn series that result from these functions.
Cheers Philip.
Cheers Phil.
Re: SeriesBand Tool and Functions
Post by Yeray » Thu Jul 15, 2010 2:59 pm
Hi Philip,
Yes, you can set it manually using the Line series and the bollinger function LowBand as series and series2 for the SeriesBand tool:
            Steema.TeeChart.Themes.BlackIsBackTheme blackTheme = new Steema.TeeChart.Themes.BlackIsBackTheme(tChart1.Chart);
            blackTheme.Apply();
            Steema.TeeChart.Styles.Candle candle1 = new Steema.TeeChart.Styles.Candle(tChart1.Chart);
            candle1.FillSampleValues();
            Steema.TeeChart.Functions.Bollinger bollinger1 = new Steema.TeeChart.Functions.Bollinger();
            line1.DataSource = candle1;
            line1.Function = bollinger1;
            bollinger1.Period = 5;
            bollinger1.Deviation = 2;
            Steema.TeeChart.Tools.SeriesBandTool band1 = new Steema.TeeChart.Tools.SeriesBandTool(tChart1.Chart);
            band1.Transparency = 75;
            band1.Series = line1;
            band1.Series2 = bollinger1.LowBand;
Snarkle
Post by Snarkle » Fri Jul 16, 2010 12:08 am
Thanks that did the trick .. now I see.
Cheers Phil.
