Series format -> Marks ->Margins query.
TonyVSUK
Post by TonyVSUK » Wed Sep 22, 2010 11:31 am
If you are in the TChart editor, and select a line series, followed by "Marks", and then "Margins", you have the option of setting the units to "Percent Font", "Percent Size" or "Pixels".
But in my TeeChartDefines.h file, I only have
// EErrorWidthUnits
const unsigned long ewuPercent = 0;
const unsigned long ewuPixels= 1;
Am I missing one? Shouldn't there be ewuPercentFont, ewuPercentSize and ewuPercentPixels?
Re: Series format -> Marks ->Margins query.
Post by Yeray » Thu Sep 23, 2010 2:16 pm
Hi Tony,
In TeeChart AX v2010 Beta I can see:
// EMarginsUnits
const unsigned long maPercentFont = 0;
const unsigned long maPercentSize = 1;
const unsigned long maPixels = 2;
TonyVSUK
Post by TonyVSUK » Thu Sep 23, 2010 2:22 pm
Are these valid in version 8.0.0.7?
Post by Yeray » Thu Sep 23, 2010 2:48 pm
Hi Tony,
No, and neither in TeeChart AX 8.0.0.8. It's new in TeeChart v2010.
TonyVSUK
Post by TonyVSUK » Thu Sep 23, 2010 2:54 pm
ok, so back to the original question, if you are in the TChart editor, and select a line series, followed by "Marks", and then "Margins", you have the option of setting the units to "Percent Font", "Percent Size" or "Pixels".
How do you set these in code given there are only two options (ewuPercent and ewuPixels)?
Post by Narcís » Mon Sep 27, 2010 10:40 am
Hi Tony,
What about using values (0, 1 and 2) instead of constants?
TonyVSUK
Post by TonyVSUK » Mon Sep 27, 2010 11:39 am
I can use constants easily enough, but that does not answer the question.
The following constants are in TChart 8.
ewuPercent = 0;
ewuPixels= 1;
How do I set the units to "Percent Font" or "Percent Size" when the only option is "Percent"?
Post by Narcís » Wed Sep 29, 2010 9:20 am
Hi Tony,
Sorry if my explanation was not clear enough. What I meant is that even constants are not defined you can use their numeric value, for example:
	m_Chart1.Series(series1).GetMarks().GetMargins().SetUnits(2);
0: Sets margins to PercentFont.
1: Sets margins to PercentSize.
2: Sets margins to Pixels.
TonyVSUK
Post by TonyVSUK » Wed Sep 29, 2010 9:30 am
Do these work in TChart 8? If they do, it means the following is incorrect.
I just want to be sure before I let my customers use it.
// EErrorWidthUnits
Post by Narcís » Wed Sep 29, 2010 9:51 am
Hi Tony,
Yes, it does. I did the tests with v8 here.
