Open Area Ends
John
Open Area Ends
Post by John » Thu Dec 09, 2004 7:45 am
When I add multiple 3D Area series to a Chart those that do not reach the end of the X-Axis are drawn open (the end is not drawn in).
This only happens when I do not plot the zero values but enter a null by using the function AddNullXY.
They looks very strange. Is there a way to close these areas ?
Any help would be appreciated.
John
Post by Narcís » Thu Dec 09, 2004 4:20 pm
Hi John,
I have posted a message with an image attached at steema.public.attachments. Could you please have a look at the image and tell us if this is the error you are referring to?
John
Post by John » Fri Dec 10, 2004 1:30 am
Thanks for the reply but where is "steema.public.attachments" area ?
I am new to this support system and cannot find it.
John
Post by Narcís » Fri Dec 10, 2004 8:38 am
Hi John,
this is our public newsgroup available at www.steema.net. You can subscribe to it using a newsreader or just running the command news:\\www.steema.net.
John
Post by John » Fri Dec 10, 2004 9:21 am
Hi Narcis,
Thank you again for your reply.
Yes, the image you have posted in public.attachments is exactly what I am seeing.
Clearly it is an error you have seem before. So what am I doing wrong ?
I am trying to show two area curves. A baseline labour at the back with an actual in front which starts after the baseline start.
I cannot show any zeros before the start of the actual or after the end.
Thanks in advance,
John
Marjan
Post by Marjan » Fri Dec 10, 2004 11:43 am
Hi, John.
Yes, this one is a drawing bug (for null point the right edge for area series in 3D is not drawn). We'll log this to our bug list and address it in next major release.
Marjan Slatinek,
John
Post by John » Mon Dec 13, 2004 2:09 am
Hi Marjan,
Thanks for your mail but I don't understand how you say this will be fixed in the next major release.
The current version of TeeChart is version 7 yet I have found this bug in version 5.03. Didn't anone spot it before ? It seems a difficult to believe that everyone has data series which cover the full range of the x-axis.
Is there any workround ? I know that verical bars can be used but I need to extend a couple of forecast graphs from the end to give the standard s-curve display.
John
Post by Pep » Tue Dec 21, 2004 10:35 am
Hi John,
Yes, other customers has noticed that, but for the moment this bug bug/missing feature has not been solved/implemented.
There's not a workaround that I know of. . Maybe you could set it to 2D when the Chart is rotated and contains a null values.
