Help lines for X and Y scale in 3D
BeijerElectronics
Post by BeijerElectronics » Wed Nov 09, 2011 4:02 pm
Is there any way to get some grid help lines for the Y and X axis in 3D mode?
It is hard to read the actual value
See attached picture (where values are 10,10 & 18,18 for both series)
Re: Help lines for X and Y scale in 3D
Post by Sandra » Thu Nov 10, 2011 10:18 am
Hello BeijerElectronics,
I recommend you use MinorGrid Axes property. You can do something as next code:
             Steema.TeeChart.Styles.Points Series1= new Points(tChart1.Chart);
             Steema.TeeChart.Styles.Points Series2 = new Points(tChart1.Chart);
             Series1.Add(10, 10);
             Series1.Add(18, 18);
             Series2.DataSource = Series1;
             Series2.RefreshSeries();
             tChart1.Axes.Bottom.SetMinMax(10, 100);
             tChart1.Axes.Left.SetMinMax(10, 100);
             tChart1.Axes.Bottom.MinorGrid.Visible = true;
             tChart1.Axes.Left.MinorGrid.Visible = true;
Can you please, tell us if previous code works as you want?
BeijerElectronics
Post by BeijerElectronics » Thu Nov 10, 2011 2:00 pm
Hello Sandra,
Thank you for a quick reply.
No, we do not want to have minor grids visible, but 3D lines for the major grid. See the picture below:
Post by Sandra » Fri Nov 11, 2011 7:57 am
Hello
I couldn't reproduce your problem with last version of TeeChart 2011 and next code:
            Steema.TeeChart.Styles.Points points1 = new Points(tChart1.Chart);
            Steema.TeeChart.Styles.Points points2 = new Points(tChart1.Chart);
            points1.Add(10, 10);
            points1.Add(18, 18);
            points2.DataSource = points1;
            tChart1.Axes.Bottom.SetMinMax(0, 100);
            tChart1.Axes.Left.SetMinMax(0, 100);
Please, can you tell us which version of TeeChart.Net are you using now?
BeijerElectronics
Post by BeijerElectronics » Wed Nov 16, 2011 10:30 am
We use the latest release version, but I see now that they are there, but the lines are almost impossible to see since we use a grid color set as white, and white lines on the yellow 3D surface makes it almost impossible to see. Is there a seperate color setting for the 3D grid lines, so that we still can use white as the major grid line color?
Post by Sandra » Thu Nov 17, 2011 3:23 pm
Hello
I think you can set the minor grid of a color and Grid of other color. You can do something as next code:
            Steema.TeeChart.Styles.Points Series1 = new Points(tChart1.Chart);
            tChart1.Axes.Left.Grid.Color = Color.White;
            tChart1.Axes.Left.MinorGrid.Color = Color.Gray;
            tChart1.Axes.Bottom.Grid.Color = Color.White;
            tChart1.Axes.Bottom.MinorGrid.Color = Color.Gray;
            tChart1.Walls.Back.Gradient.Visible=false;
            tChart1.Walls.Back.Transparency = 100;
            tChart1.Panel.Color= Color.Black;
            tChart1.Panel.Gradient.Visible = false;
Can you tell us if previous code works as you expected?
