Bug in Anit-Alias tool when using pie chart in 2D mode
marder
Re: Bug in Anit-Alias tool when using pie chart in 2D mode
Post by marder » Tue Nov 22, 2011 12:41 pm
Here is the sample project.
IDE is Delphi XE2 Update2. TeeChart V2011.04 source code edition is used.
Best regards.
TestProject.zip
Test project using TGDIPlusCanvas - produces exception on Delphi XE2 Update 2
(7.54 KiB) Downloaded 778 times
Post by Narcís » Tue Nov 22, 2011 2:30 pm
Hi marder,
The project works fine for me here using the source code version of build 2011.04.41118. I had to change some uses adding the VCLTee prefix. Find attached the project with my modifications. Does this work fine for you?
TestProject.zip
(74.89 KiB) Downloaded 808 times
marder
Post by marder » Tue Nov 22, 2011 2:58 pm
Dear Narcis.
...here using the source code version of build 2011.04.41118.
Where do I see the detailed Build version?
In the Windows Explorer "Properties" dialog the version of the Installer I downloaded yesterday is shown as "0.4455.0.0".
Under Windows installed programs I see only "Version 2011" in the column "version".
Post by Narcís » Tue Nov 22, 2011 3:00 pm
Hello marder,
You can find the build version in the release.txt in the installation folder or right-clicking on a TChart component at design-time and selecting the "About" option.
marder
Post by marder » Wed Nov 23, 2011 9:26 am
Dear Narcis.
I think there were some issues when updating the former source code version of TeeChart V2011 to the newest.
I did not uninstall TeeChart and reinstall again and the exception is gone.
Thanks for your help!
