Problems installing TChart
I downloaded TChart 4.1.2012.202284 eval version and tried to install it at my Win 7 64 bit PC.
The expected controls do not appear in VS2010 C# Express.
There was a warning saying Error running ...ToolBoxEditor2010.exe unhandled exception : SystemNullReferenceException ...
So looked for a solution and found this:
http://www.teechart.net/support/viewtop ... =4&t=13165
I created a new tab in the toolbox and added "C:\Program Files (x86)\Steema Software\Steema TeeChart for .NET 2012 Evaluation 4.1.2012.02284\net40\x86\TeeChart.dll".
With that the controls do appear in the toolbox. OK.
But when i drag and drop the TChart control to my form, a message pops up saying the TeeChart Evaluation version has expired.
I downloaded the exe today and filled in the numbers from the received mail.
Whats wrong?
Thanks in advance
Pat
Whats wrong?
Thanks in advance
Pat
Re: Problems installing TChart
Hi Pat,
Did you had installed any TeeChart evaluation version in the past on that machine? That could be the reason for the current version saying it has expired. Anyway, I'm going to send you an email with a tool to extend the evaluation period. If the utility says it can't find the expiration date, the problem will probably be that the installer failed when trying to write that date in the register. Then, please, reinstall the component making sure you run it with admin privileges and there is no registry blocking software (anti-virus, anti-spyware,...) running on the machine.
Hello Narcís,
Thank You for the quick replay!
No, its an new PC and Win 7 installation. First time istalled TChart here.
Also tried it at a notebook with Win 7 64 bit, the same behavior!
I deinstalled TChart and deactivated the realtime protection in MS Security Essentials, the only protection tool on the PC.
Than reinstalled TChart with admin rights. Same behavior, same warning and same message with eval period expired!
In the past i worked with TChart very successfully for the old company.
Now i would like to excite my new boss for TChart to buy it for a new project.
Would be great to get it running
Would You please post here an email address, where i could answer if necessary?
My old email address deposited by my old tchart license is not working anymore.
Thanks Pat
Edit: Changed my email address in profile
Thanks Pat
Hi Pat,
Ok, I forwarded the email I sent you to the new forums address. It's fine for us posting your technical inquiries here. For licensing or sales issues please send an email to sales at steema dot com.
Hi Narcís,
Did You sent me an email to my sunrise address? I got no mail yet , also checked spam. Sorry.
Pat
Pat
Hi Pat,
Yes, I used the sunrise address. Find attached the EvalExtender tool. Please let me know when you have download it.
OK. I downloaded it.
When i start it, Evalextender sais "Check falied. No eval date found".
Any idea?
Pat
Any idea?
Pat
Hi Pat,
I've checked it here and the evaluation extender should create the expiration date if it isn't present. So the "Check falied. No eval date found" shouldn't appear if the utility has access to the registry.
I know you've tried it in two different machines, and this puzzles me, but let me insist asking you to check again you are running the EvalExtender utility with high privileges and no security software is blocking it.
Hello Yeray,
You are right. With "execute as admin" the EvalExtender works. Thanks.
But now i have errors when compiling. See the attached image.
I added a reference to the project by "...\net40\x86\TeeChart.dll". Hope this is right. Without i cannot write "using steema;".
Boy, this is hard!
Pat
Boy, this is hard!
Pat
- TChart_Error.jpg (230.96 KiB) Viewed 14326 times
Hi Pat,
You are on a x64 OS, aren't you? If that's the case you should be referencing the x64 assemblies or explicitly build your projects as x86 applications.
Hello Pat,
Moreover, I suggest you check if your .Net Framework of your application, isn't Client Profile. To check it, you can follow next steps:
1.- Click on WindowsApplication with right button and select properties
2.- Go to Framework target and change Framework 4.0 Client Profile to Framework 4.0
3.- Run again your project.
On the other hand, If you want work with a Client Profile application you need do next:
1.- Go to references and remove TeeChart.dll
2.- Do click with right button and select Add References
3.- Go to the folder where you install TeeChartFor .Net 2012 and you select TeeChart.Client.dll
4.- Run again your project.
Hello at all
I changed framework target to "Framework 4.0" and it WORKS! Thank You Sandra.
The project reference for TChart.dll is the x86 one.
The elements for the toolbox are also from the x86 TChart folder.
Yes, i have a 64bit PC.
Last question:
Is it possible to write 32bit apps with TChart components on a 64bit machine?
How to do that?
Have a nice weekend.
Pat
Last question:
How to do that?
Pat
Hi Pat,
Kudos to SandraI changed framework target to "Framework 4.0" and it WORKS! Thank You Sandra.
Yes, applications are compiled in 32-bit by default as explained here. Some more detailed info here.Is it possible to write 32bit apps with TChart components on a 64bit machine?
How to do that?
Thanks, have a good oneHave a nice weekend.
Thank you for the links!
Now, every thing works fine for me
Best Regards
Pat
Best Regards
Pat
