I have just upgraded to TeeChart.Net v2012 (from V3) and my projects are building fine on my PC, but my build server is now failing with the error message "An instance of type 'Steema.TeeChart.Chart' was being created, and a valid license could not be granted for the type 'Steema.TeeChart.Chart'." I guess that I have to register TeeChart as a design time component in the registry on the build server, but I cannot find a TeeReg for V2012 on the download page. Can I use the one for v2010 (TeeRegv2010.exe)?
Also, the build server still need to be able to build with TeeChart.Net v3. Will register v2012 conflict with this in any way?
Lars Magnus Nordeide
TeeRegister tool for v2012
Re: TeeRegister tool for v2012
Hello Imno,
http://www.teechart.net/support/viewtopic.php?t=6711
http://www.teechart.net/support/viewtop ... f=4&t=7677
If it doesn't help, please send me exactly error because we can investigate it here and try to give you a good solution.
Yes you can use the TeeRegV2010, so internally it works with version 4. On the other hand, If it doesn't help you I recommend take a look in these threads to try to solve your problem.I have just upgraded to TeeChart.Net v2012 (from V3) and my projects are building fine on my PC, but my build server is now failing with the error message "An instance of type 'Steema.TeeChart.Chart' was being created, and a valid license could not be granted for the type 'Steema.TeeChart.Chart'." I guess that I have to register TeeChart as a design time component in the registry on the build server, but I cannot find a TeeReg for V2012 on the download page. Can I use the one for v2010 (TeeRegv2010.exe)?
You can install and register in same machine different versions of TeeChartFor.Net without problems.Also, the build server still need to be able to build with TeeChart.Net v3. Will register v2012 conflict with this in any way?
Thanks for the swift reply. Using TeeRegV2010 fixed the issue on the build server.
Lars
Lars
