My program monitors for "Events" that cause TChart to place an Annotate & DLine on the graph to mark the time of the event.
I'm using the basic code Yeray provided in an earlier post, and that part seems to be working fine.
First Issue:
The problem I'm now having is that each time a new Annotate/DLine pair are generated the DLine of all previous Annotate/DLine pairs dissapears. Which ever Annotate has the focus, the accompaning DLine is visible, yet no other DLine is. Can't figure out why. What other seemingly unrelated conditions might have an effect on the DLine?
Second Issue:
Having generated a DragMark, setting it's active parameter to True, and assigned a series, I'm not able to move the Annotate/DLine pair. I have looked at the DragMarks OnDragged Demo Project, but am unable to determine how to make this work. Am I mistaken about the function of the DragMark tool?
Can someone help please?
Annotate, DLine, and DragMark issues
Re: Annotate, DLine, and DragMark issues
Hi tirby,
I assume Yeray's example is this, right?I'm using the basic code Yeray provided in an earlier post, and that part seems to be working fine.
If I understand your problem it works with Yeray's example, doesn't it? You could check which changes have you done to the code that might have affected that.First Issue:
Yes, this is to drag standard series marks. Don't forget that the Annotation + DragLine tools combination are not original TeeChart series marks. To implement annotation dragging you should change its custom position in the OnMouseMove event or replace Annotation tools by Rectangle tools which already supports dragging. Also, find attached an old project I did to demo Annotation tool dragging.Second Issue:
- DragAnnotationEditText.zip
- (1.99 KiB) Downloaded 912 times
So I discovered that if the color is set to vbBlack, then the line(s) will dissappear when the focus shifts to a different pair. My fix was:
Not sure why, and I really want to set the color to Black.
The use of the Rectangle Tool works good!
TChart1.Tools.Items(ToolSelected + 1).asDrawLine.Lines.Items(0).Pen.Color = vbRed
Hi tirby,
If you still find problems with it, please try to arrange a simple example project we can run as-is to reproduce the problem here.tirby wrote:Not sure why, and I really want to set the color to Black.
