Export Chart Question
hansw
Post by hansw » Mon Dec 29, 2003 4:14 am
Export to jpg or GIF works fine.
In the OnAfterDraw() I do several line drawings, and these are never exported with the chart.
How can I make it export my drawings with the chart ?
Hans W
Post by Pep » Mon Dec 29, 2003 8:24 am
Hi Hans,
there's no problem getting Canvas drawing methods and properties to write to a JPEG file (in the OnAfterDraw() event recommended in Tutorial 13 - Custom Drawing on the Chart Panel) using the following example:
Private Sub Command1_Click()
With TChart1
    .Export.SaveToJPEGFile "C:\TestFiles\file.jpg", False, jpegBestQuality,
95, 400, 400
End With
Private Sub Form_Load()
TeeCommander1.Chart = TChart1
With TChart1
    .AddSeries scLine
    .AddSeries scLine
    For i = 0 To 1
        .Series(i).FillSampleValues 10
    Next i
End With
With TChart1
    .Canvas.Font.Name = "Verdana"
    .Canvas.Font.Size = 16
    .Canvas.Font.Color = vbCyan
    .Canvas.TextOut 200, 200, "HELLO"
End With
Could you test if it works for you ?
Josep Lluis Jorge
http://support.steema.com
hansw
Well I think it should work, but it does not !
Post by hansw » Mon Dec 29, 2003 4:14 pm
OK I'm drawing in the OnAfterDraw() like this
m_Chart1.GetCanvas().GetPen().SetColor(pt.crColor);
m_Chart1.GetCanvas().MoveTo( X, m_Chart1.GetAxis().GetTop().GetPosition());
m_Chart1.GetCanvas().LineTo( X, m_Chart1.GetAxis().GetBottom().GetPosition());
Then when the user clicks send chart by email I use this code
The chart is fine, but the lines do not show on the jpeg image.
What now ?
Hans W
void C_TeeChartView::OnEmailChart()
char lpBuffer[MAX_PATH];
DWORD error = GetTempPath(MAX_PATH, lpBuffer );
strcat (lpBuffer,"Chart1.jpg");
m_Chart1.GetExport().GetAsJPEG().SetCompressionQuality(90);
m_Chart1.GetExport().GetAsJPEG().SetGrayScale(false);
m_Chart1.GetExport().GetAsJPEG().SetHeight(400);
m_Chart1.GetExport().GetAsJPEG().SetWidth(600);
m_Chart1.GetExport().GetAsJPEG().SaveToFile(lpBuffer);
m_Chart1.GetExport().EmailFile(lpBuffer);
Post by Christopher » Mon Dec 29, 2003 4:35 pm
Hi -
I imagine that this is because the C_TeeChartView::OnEmailChart() event, which is not a TeeChart event, is being called before the Chart has fired the OnAfterDraw() event. Have you tried calling ITChart.Repaint() or IEnvironment.InternalRepaint() before you export the Chart to JPEG?
Thank you!
http://groups.google.com
http://codenewsfast.com/
hansw
Almost works... still has problems
Post by hansw » Tue Dec 30, 2003 5:18 am
I used m_Chart1..Repaint() which did make the extra lines appear, however the annotations are no in the correct place.
By correct place I mean X,Y the are way off form where they appear in the chart before it is exported.
So I looked for IEnvironment.InternalRepaint()
And as usual I could not find it.
C++ users only have the few (sometimes not working) examples and a small tutorial for help, and the hints in the VC IDE which can take hours use and are of very little help for learning TeeChart.
VB help for VC+= users is not good enough. I have zero use for VB and can't spend time learning it. It's a craby language about as bad as delphi.
end
who has time to type all those begin and ends when a simple
does the same thing... long live VC++
Post by Christopher » Tue Dec 30, 2003 7:20 am
Hi --
Have you had a look for "IEnvironment" in the Index of TeeChart's Help file?
Under "InternalRepaint" you will find a VB example that looks a bit like this:
With TChart1
    .Environment.InternalRepaint
End With
In VC++, the "translation" looks like this:
m_Chart1.GetEnvironment().InternalRepaint();
Thank you!
hansw
Post by hansw » Tue Dec 30, 2003 10:56 am
thanks..
I still hate VB :-) crap language...:-)
With
End With...
That requires 10 more characters than sthe same statement in C, I've already had carpal tunnel surgery... crap language... :-)
