Memory leak in the Surface Series
anauta2014
Post by anauta2014 » Wed Feb 26, 2014 12:28 pm
I found a memory leak in the Surface series, will compile test1 program and after start will check memory by TaskManager
test1.zip
(48.37 KiB) Downloaded 807 times
With best regards
Vladimir
Re: Memory leak in the Surface Series
Post by Yeray » Thu Feb 27, 2014 3:42 pm
Hello Vladimir,
I think with GDI it works better than with GDI+, could you please confirm it?
Delphi testing application:
uses Chart, TeeGDIPlus, TeCanvas, TeeSurfa;
var Chart1: TChart;
    Series1: TSurfaceSeries;
  Chart1:=TChart.Create(Self);
  Chart1.Parent:=Self;
  Chart1.Align:=alClient;
  Chart1.View3D:=false;
  Chart1.Legend.Visible:=false;
  Series1:=Chart1.AddSeries(TSurfaceSeries) as TSurfaceSeries;
  Series1.FillSampleValues(128);
  RadioGroup1Click(Self);
procedure TForm1.Timer1Timer(Sender: TObject);
var x, z: Integer;
  for x:=0 to 127 do
    for z:=0 to 127 do
      Series1.Value[x,z]:=random(512);
procedure TForm1.RadioGroup1Click(Sender: TObject);
  case RadioGroup1.ItemIndex of
    0: if Chart1.Canvas is TTeeCanvas3D then
          Chart1.Canvas:=TGDIPlusCanvas.Create;
    1: if Chart1.Canvas is TGDIPlusCanvas then
          Chart1.Canvas:=TTeeCanvas3D.Create;
After confirming it, if you want you can add it to the bugzilla tracking system:
http://bugs.teechart.net/
anauta2014
Post by anauta2014 » Fri Feb 28, 2014 8:23 am
Hi Yeray
I've just checked with the GDI rendering, the bug exists also with the same rate of the memory leak.
By the way, this bug exists only in the last version of the TeeChart, the previous works fine, for this reason I am using now the previous version of the TeeChart (from November 2013).
The TColorBand bug (my other report) also is absent in the previous version.
With best regards
Vladimir
Post by Narcís » Fri Feb 28, 2014 11:30 am
Hi Vladimir,
Thanks for your feedback. I could reproduce the issue here and added it to the bug list (ID611). Please feel free to sign up at Steema Software's bugzilla platform to be able to get automatic issue update notifications.
anauta2014 wrote:The TColorBand bug (my other report) also is absent in the previous version.
It has just been fixed for the next maintenance release, see David Berneda's comment.
Post by Narcís » Fri Feb 28, 2014 2:04 pm
Hi Vladimir,
This is not a memory leak, see David's comment.
