Can not load TeeChart for XE5
Bill
Post by Bill » Wed Mar 12, 2014 1:01 pm
I've just installed TeeChart2014RADXE5 and I'm getting the following msg when I start BCB XE5
The procedure entry point @vcltee@Teengine@TCustomChartSeries@SetShowInLegend$qqro could not be located in the dynamic link library Tee919.bpl.
I have the same configuration as my priviouse post.
-Bill
Re: Can not load TeeChart for XE5
Post by Yeray » Wed Mar 12, 2014 3:01 pm
Hi Bill,
Similar to here then, can you please confirm:
- Does your IDE only have BCB personality (not delphi)?
- Does the error still appears if you run TeeInstall.exe to uninstall the component from the IDE, and run TeeInstall.exe again to reinstall the component into the IDE?
Bill
Post by Bill » Wed Mar 12, 2014 5:00 pm
Corrrect. I only have C++, no Delphi.
I tryed to run TeeInstall and got the same error massage.
Post by Yeray » Thu Mar 13, 2014 12:58 pm
Hi Bill,
I'll try to prepare the same environment than you have to reproduce this. What OS are you running?
Please read the "how-to post instructions" below in my signature.
Bill
Post by Bill » Thu Mar 13, 2014 2:03 pm
No need to do more. After removing all TChart related files and re-installing the latest version and re-booting, the problem has gone away.
Best
-Bill
Post by Yeray » Thu Mar 13, 2014 4:12 pm
Hello Bill,
Thanks for sharing what solved the problem for you.
