override which series appears in legend
WCantrall
Post by WCantrall » Tue Apr 15, 2014 4:57 am
Is there a way to exclude a series from appearing in the legend? It must remain visible.
Re: override which series appears in legend
Post by Yeray » Tue Apr 15, 2014 7:33 am
WCantrall wrote:Is there a way to exclude a series from appearing in the legend? It must remain visible.
I've just added it to the wish list to be implemented in future releases:
http://bugs.teechart.net/show_bug.cgi?id=731
amjonas
Post by amjonas » Tue Jun 10, 2014 11:48 am
Has this been implemented yet?
We're porting some TeeChart_PHP scripts to Javascript / HTML5 and rely on it quite heavily. Happy to test a beta version, as our system won't be going live immediately.
Alternatively, is there a way to override a legend draw method/event?
Kind regards
Mark
Post by Yeray » Tue Jun 10, 2014 2:30 pm
Hi Mark,
I'm afraid it hasn't been implemented yet.
I've incremented the issue Importance so it can be reviewed asap.
amjonas
Post by amjonas » Mon Jan 26, 2015 12:19 pm
I've implemented a crude "showInLegend" into javascript version 2014.07.31.1.7 (attached) if that's of any help to anyone?
Hopefully it can be tidied up adopted in the main source :wink:
Mark
Post by Yeray » Mon Jan 26, 2015 12:24 pm
Hi Mark,
I've removed the attachment in your post because it contains a the TeeChart sources.
We'll study your implementation and we'll be back to you here asap.
**** EDIT ****
For those customers interested in the implementation Mark has just proposed, I'll try to explain it here:
1. Initialize the property at Tee.Series:
Tee.Series=function(o,o2) {
  this.chart=null;
  this.data={ values:[], labels:[], source:null }
  this.yMandatory=true;
  this.horizAxis="bottom";
  this.vertAxis="left";
  this.showInLegend=true;	//AMJ: added ShowInLegend
2. Add the appropriate condition at drawSeries:
  this.drawSeries=function(index,order) {
    var s=chart.series.items[index];
    if ((this.showHidden || s.visible) && s.showInLegend) {	//AMJ: added ShowInLegend
      this.drawItem(s.titleText(index),s,order,true);
      return true;
      return false;
3. Change itemsCount accordingly:
  this.itemsCount=function() {
    if ((st==="values") && (result>0))
       result=ss.firstVisible().legendCount();
      if (((st==="auto") && (result>1)) || (st==="series")) {    //AMJ: added ShowInLegend - remove count where not showInLegend?
        var t;
        for(t=0; t<ss.items.length; t++)
          if (!ss.items[t].showInLegend) result--;
      if (result==1)
amjonas
Post by amjonas » Mon Jan 26, 2015 12:34 pm
Yeray wrote:I've removed the attachment in your post because it contains a the TeeChart sources.
Whoops - Sorry - didn't think!
Post by Yeray » Mon Jan 26, 2015 12:35 pm
amjonas wrote:Whoops - Sorry - didn't think!
No worries. I've edited the post above to show your proposal.
Thanks for sharing it!
amjonas
Post by amjonas » Fri Jul 03, 2015 11:21 pm
There have been two releases of Javascript/HTML5 since this post, and it's not been implemented in the core.
Any problems with the implementation? it matches VCL/PHP which we also use.
Slightly bored of continuing to have to update the new releases!
Mark
Post by Yeray » Mon Jul 06, 2015 10:09 am
Hello Mark,
Excuse us for the delay here.
I've added your implementation to the internal sources so the next maintenance release with include it.
Post by Yeray » Tue Jul 07, 2015 8:11 am
Note we decided to change showInLegend for legend.visible.
So with the next update you'll be able to do:
Chart1.series.items[0].legend.visible=false;
