I am using the latest 2015 version and it looks like the smoothing function does not perform any more when working with TPoint series? Attached is a simple example, if I click the button I get a strange straight line only.
Problem with Smoothing function
- Sample.zip
- (2.6 KiB) Downloaded 1024 times
Re: Problem with Smoothing function
Could you please tell us with what TeeChart version this sample behaves different?
I am using the latest TeeChart 2015.14.150120. If I use another series type like Line series it works ok.
Try this:
Try this:
type
TSeriesAccess=class(TChartSeries);
TSeriesAccess(Chart6[1]).SetHorizontal;
Chart6[1].FillSampleValues(20);
teefunction1.ReCalculate;
Hello Yeray,
Thank you very much for looking into this. I implemented your suggestion in my app and it works ok but I need to ask, is this a temporary fix or this is by design the way point series should be used with smoothing function?
Hello johnnix,
This is by design. TPointSeries is a vertical series while, in your example, you are using a THorizLineSeries, which is a horizontal series. Given that, you need to make the point series to be horizontal so it can work with an horizontal line series.
Hello Narcis,
Thank you very much for the clarification and quick answers.
