Hello
I installed the new version 2025.44 and noticed some problems with my program.
After investigation, i create a small demo program, see attachment.
Compile it with v44, the start it and press the "view" button, then "hide". then you got a exceptions. I also got an exception, when i delete a Series at design time in the IDE.
Compile and run it with <=V43 it runs without any problems.
Delphi 12.3.1 Build the program with Win32 and Win64.
Hope this will be fixed.
Thanks in advanced
Gregor
Exceptions with Version 2025.44
- TestTChart.7z
- (70.95 KiB) Downloaded 11 times
Re: Exceptions with Version 2025.44
Yes, that's a side effect of a bug in v2025.44 (#2777), which was identified and fixed here.
Find below the full git diff:
--- a/Chart.pas
+++ b/Chart.pas
@@ -418,6 +418,7 @@ type
ILegend : TCustomChartLegend;
+ procedure FontChanged(Sender: TObject);
function GetFont:TTeeFont;
procedure SetAlign(const Value:TCanvasTextAlign);
procedure SetCustom(SetPos:Boolean);
@@ -5519,6 +5520,14 @@ begin
result:=Assigned(FFont);
+procedure TLegendItem.FontChanged(Sender: TObject);
+begin
+ SetCustom(False);
+ if Assigned(ILegend) then
+ ILegend.CanvasChanged(Sender);
+end;
function TLegendItem.GetFont:TTeeFont;
var Old : Boolean;
@@ -5536,6 +5545,12 @@ begin
FFont:=TTeeFont.Create(nil);
+ {$IFDEF FMX}
+ FFont.Brush.OnChanged:=FontChanged;
+ {$ELSE}
+ FFont.OnChange:=FontChanged;
+ {$ENDIF}
result:=FFont;
@@ -5635,11 +5650,6 @@ begin
result:=TLegendItem.Create;
result.ILegend:=ILegend;
- if ILegend.InternalLegendStyle=lsAuto then
- ILegend.CalcLegendStyle;
- result.Text:=ILegend.FormattedLegend(Index);
inherited Items[Index]:=result;
Ok, thanks. Will Steema create a new installer to fix that?
Yes, we'll publish new installers as soon as possible.
Thanks a lot
